Carby Enrichiner
Old Sep 1, 2013 | 11:30 AM
ironoxide's Avatar
ironoxide
Default Carby Enrichiner
My '99 with the stock carb takes about 5 seconds to start after I pull the Enrichiner all the out in preparation for a cold start. As recommended in the owners manual I do not twist the throttle during starting. I also leave the bike on it's jiffy stand. Does the bike need to be level and fully upright for better starting? Otherwise, the bike starts well. She starts right up when hot with a slight twist of the throttle. Thanks in advance!!
Old Sep 1, 2013 | 11:34 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
5 seconds is a long time to hold in the start button to me.
Id try giving it a twist or two next time you start her cold.
I always start mine while she is on the kick stand.
Old Sep 1, 2013 | 11:35 AM
traildog's Avatar
traildog
Hmmmm. I always give her a squirt of fuel, pull the enrichener , and she fires right up.
Never heard anything aboutt the bike being level.
Old Sep 1, 2013 | 11:40 AM
ironoxide's Avatar
ironoxide
Thanks gents. I'll give it a try in about 30 minutes.
Old Sep 1, 2013 | 01:39 PM
ironoxide's Avatar
ironoxide
Default Bingo
Well Gents, just as you advised, two twists of the throttle, pull the Enrichiner, and she fired up right away!! Thanks again for the good advise!!
Old Sep 1, 2013 | 01:52 PM
Kushman's Avatar
Kushman
With the cv your bike has (assuming it is the stock carb) you do NOT give the throttle a twist before starting. This is well documented when HD changed over to the CV as many of us that had earlier carbs would give it a couple twists and flood the bike, took a while for me to get used to it.
I would check for bad fuel or plugs first then look for an intake leak. You might also have to clean your carb and check enricher circut, float height and jetting.
I changed my 85 to a used CV that I cleaned and installed new jets. Cold start - Turn on fuel, turn on ignition, check in N hit button and it will start pretty much as quick as I can let go. Hot start same as above with no enricher.
And it does not matter that it is on the side stand.
Old Sep 1, 2013 | 02:33 PM
bluharley's Avatar
bluharley
If my bike has been sitting a day or two with the fuel **** off, I have to wait a couple second for gas to fill the bowl. Starts on first crank after that.
Old Sep 1, 2013 | 02:40 PM
traildog's Avatar
traildog
Must be different for the S&S carb.
Bertha had a stock carb with bigger jets. I ALWAYS had to give her 1 twist to start.
Old Sep 1, 2013 | 03:25 PM
texashillcountry
Dirt don't hurt
It may be well documented but from my experience it is wrong.
Old Sep 1, 2013 | 03:38 PM
Spanners39's Avatar
Spanners39
Agreed, depending on where you live, altitude, ambient temp etc you may have to give your throttle a twist before starting. When I converted my Ironhead to CV it was the opposite, no twists or it wouldn't start....my Evo Wide Glide needed a coupla twists and my Twin Cam needs a twist as you hit the button in what we call our winter.
