Oil pressure problems persist...getting worse.
Old Sep 8, 2013 | 09:41 AM
HarDlife's Avatar
HarDlife
Default Oil pressure problems persist...getting worse.
As some of you already know I have an oil light that won't go out @ idle (when hot). I have done as suggested and increased idle speed, changed tank-to-pump feed hose, checked tightness of all hose connections, replaced check valve spring w/ new HD one, eliminated switch as problem by verifying low pressure w/test gauge, and changed oil twice and filter three times.
Oil light still comes on at idle after riding about 10 minutes or so. Starts as a flicker, and gets steadily worse to the point that I have to rev it over 1500 rpms to make it go out! Motor runs absolutely fine, no audible scary noises the whole time. This would indicate to me there is good flow (per se), just poor pressure?
At this point I'm thinking there are tolerance issues internally (cam bushing, lifter blocks, oil pump itself?) The only other thing I've read is the pressure relief valve can stick open? I tried to get the little bugger out w/ a magnet, wouldn't budge.
I really didn't want to tear into a motor w/ only 14k on it, but that's the direction this seems to be headed. I bought the bike BECAUSE it was low miles, and I figured I could enjoy it for a little while before any major wrenchin'. 200 miles in the seat and here I am.
If anyone has any ideas/suggestions I would LOVE to hear them! I just wanna ride my bike...
Old Sep 8, 2013 | 02:23 PM
traildog's Avatar
traildog
I wonder if running some seafoam through it would help?
Old Sep 8, 2013 | 02:58 PM
Spanners39's Avatar
Spanners39
My pick is cam bushing at this point.
Old Sep 8, 2013 | 03:38 PM
Tee&Vee's Avatar
Tee&Vee
https://www.hdforums.com/forum/evo-c...le-solved.html
This gimmick will workforce you. Wtf is there to lose but time and money???
Old Sep 8, 2013 | 04:07 PM
traildog's Avatar
traildog
I wonder if running some SEAFOAM through it would help.......
Old Sep 8, 2013 | 04:09 PM
traildog's Avatar
traildog
Maybe running some SEAFOAM through it would help.......
Old Sep 8, 2013 | 04:14 PM
bluharley's Avatar
bluharley
You're an addict, TD, get help....
Stiggy's Avatar
Stiggy
I doubt it....( but I'll only say it once.)
Old Sep 8, 2013 | 04:22 PM
traildog's Avatar
traildog
Wow, just WOW.......Seafoam.......good stuff..........I like it............
Old Sep 8, 2013 | 04:29 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Yeah we can tell!!!!!!!!!
