softail ignition switch swap?
Old Sep 11, 2013 | 09:48 PM
machinehed's Avatar
machinehed
Default ign. switch.
Originally Posted by Mrrick
I have a 1989 fxstc with the 6 lead screw connector terminal switch. Has anyone converted theirs to the 93 up switch with the 3 terminal plug in? Can it be done?
I see your having trouble trying to get a reply here and as your querrie is a wiring nightmare as described , i will try to help you here.
As the wiring type dude here i will offer my suggestions to you ...
Yes ... you can rewire anthing including this system from 6 wire ign. switch to 3 wire " But " you will need a complete schematic wiring diagram and you must know how to read it to ensure you dont fry everything in the process as the ign. switch is a primary switching component .
I suggest the following...
1) replace the 6 pin standard ign. switch with any automotive shop available same unit for like $ 15.00. These universal units are stout and labeled and easy to wire .
2) repair the unit you have by resoldering the broken connectors.
3) replace the unit with an available HD unit for big bucks .
Powercat87
Oct 2, 2023 02:33 PM
1962300
Flathead
Mar 7, 2013 07:24 AM
Shifters90
Dec 27, 2011 10:15 PM
Mal74
Mar 23, 2011 09:30 PM
markuhen
Jul 4, 2006 06:11 PM
