not starting
Old Oct 21, 2013 | 02:57 PM
Spanners39's Avatar
Spanners39
If you got the cam, breather and crank marks all good it should be fine....unless you got the ignition timing wrong.....did you seat the ign timing cup into the notch on the cam before tightening the bolt?
It should run without mods to the fuel map...is all your EFI wiring plugged in correctly?
Old Oct 21, 2013 | 06:58 PM
Schulte94's Avatar
Schulte94
More than.one timing mark?!?! Well hell! I only saw the one dash! Mine is a 96.
Old Oct 21, 2013 | 07:03 PM
Schulte94's Avatar
Schulte94
When.I put on.the nose cone I set the ignition cup into it, finger tightened the bolt and then tightened it down. The ignition plate is pre set on the efi models. It only bolts up with the Allen headed bolts in the two holes.
Old Oct 21, 2013 | 07:28 PM
chester1957's Avatar
chester1957
Default Found notch?
When you put the cup on did you rotate it till it seated in the notch.
Only one mark on crank, 2 on the cam. One for crank and other for breather.
Old Oct 21, 2013 | 07:31 PM
chester1957
Did you unplug the ignition plate connector above the rear cross member?
Old Oct 21, 2013 | 08:24 PM
Spanners39's Avatar
Spanners39
Ign timing usually has two sets of marks, one for California and one for the real world but it wouldn't stop it running. Not sure what year they started doing it though.
Old Oct 21, 2013 | 08:36 PM
Schulte94's Avatar
Schulte94
Well fellas start the laughing and heckling now...
so in my rush to get my scoot going so I could.get on it and ride I didn't.second check that the dimple on the ignition cup was in the slot/keyway on the cam... so yeah...
Thank you all so much for your advice and suggestions!! No to readjust the pushrods properly and tie everything up!
Old Oct 21, 2013 | 08:48 PM
Schulte94's Avatar
Schulte94
Now**
evobigape
EVO
11
Mar 7, 2018 05:46 AM
Evosupercharged
Blowers/Turbos/Nitrous Oxide
Dec 11, 2016 11:20 AM
azlou66
EVO
Sep 19, 2016 05:26 PM
Blown 331
EVO
15
Feb 23, 2007 08:53 AM
ken
Exhaust System Topics
Jan 25, 2005 10:00 PM
