Right oil filter?
Old Oct 30, 2013 | 04:09 PM
  #51
RHPAW's Avatar
RHPAW
Originally Posted by Jim Kraft
HD lists the later Twin Cam filter as a retrofit back to Shovels,
Shovels have an oil tank. The stock application filter resides inside the tank. Not even close to an Evo OR Twinkie filter.
Old Oct 30, 2013 | 04:19 PM
  #52
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Not all Shovels used that configuration. Some later models used the same external spin on oil filter as the Evo.
Old Oct 30, 2013 | 04:24 PM
  #53
RHPAW's Avatar
RHPAW
Still a bit of a blanket statement...
Old Oct 30, 2013 | 05:04 PM
  #54
Jim Kraft's Avatar
Jim Kraft
You are right RHPAW; I should have clarified that as the only Shovels the TC filter fits is 80 thru 84. If I remember right there were a few Shovels built in 84 and the rest were EVO's.
Old Oct 30, 2013 | 05:23 PM
  #55
Harleycruiser's Avatar
Harleycruiser
People have been using alternate oil filters on their Harleys for decades.
Lots of guys with Shovelheads ran adapters that used automobile oil filters before the small motorcycle spin on filters were available.
Not once have I read a post or heard about any damage or premature wear caused by any oil filter.
Dan you made me think, first I was going to say several times, but now that I think if it only once. An Indi who had a bike come in, motor fried, no oil circulation and wrong filter.
However I do not remember the circumstances, believe it was a evo but I am not going to say anymore because I don't remember, and who know the real circumstances.
It did make enough of an impression to put me in the "Why take a chance" group.
My biggest fear in not using a "car" filter but getting the wrong filter.
Like I said before the only time I tried to use an aftermarket filter I bought at an Indi and it would not screw on, that scared me enough to never try again.
I wont use a fram, or wix, however I am sure both are made by the same company that makes HD.
Wish Pure would recommend one to fit bikes since they discontinued their bike filters.
Old Oct 30, 2013 | 05:37 PM
  #56
aces&8s's Avatar
aces&8s
Not true.
Please back up your statment with more than 2 words. Apparently you know more than the dealership that sells the filters.?? ILL stick with the 77a that is made for the EVO.
Old Oct 30, 2013 | 05:38 PM
  #57
Dan89FLSTC's Avatar
Dan89FLSTC
If a filter were put on an Evo, that did not allow the oil to pass through, there would first be a huge mess, because the oil would not return to the tank, and would instead blow out the breather.
Wow, I used a lot of commas in that run on sentence....
Old Oct 30, 2013 | 05:40 PM
  #58
Dan89FLSTC's Avatar
Dan89FLSTC
A TC gerotor pump moves more oil than a wimpy gear type Evo/Shovel pump. The TC requires more oil due to its design, including the oil jets used to cool the pistons and cylinders.
And that is why I said that your statement is not true. Care to back up your statement as to why you say a TC needs less oil flow?
Yes, I think I probably know more than the dealership that sells the filters, and apparently I`m not the only one who thinks this...
Just wanted to be sure because the parts counter guy may not know the diffrence and try sell ya one, like they did me.
Old Oct 30, 2013 | 06:16 PM
  #59
Spanners39's Avatar
Spanners39
My opinion is that whereas most of us would happily spend 500 bucks on a cam-swap, we tend to be too cheap-*** to buy a proper filter....discuss....
Old Oct 30, 2013 | 06:28 PM
  #60
Dan89FLSTC's Avatar
Dan89FLSTC
Sounds reasonable to me...
