ANOTHER Rubber Mount Softail Thread...
Old Jan 2, 2014 | 11:10 PM
LoBoT's Avatar
LoBoT
Wait, Wait. If it's shocks in the way of the tranny drain plug, would it work to re-route the dyna EVO outlet by a drain tube secured to the outlet?
Old Jan 2, 2014 | 11:18 PM
LoBoT's Avatar
LoBoT
Nope. Yer right Spanners. The swingarm mount is gonna nix it.
Old Jan 3, 2014 | 02:05 AM
Spanners39's Avatar
Spanners39
Originally Posted by texashillcountry
Just out of curiosity what if you ran a chain final drive.
Would that stand up any better than a belt?
I'm only asking cause it is an interesting problem.
It would be a disaster with a chain because it would chew up the sprockets (and the chain) in no time and be really harsh. Probably take out the tranny output bearing fairly pronto as well.
You just have to accept that H-D knew what they were doing when they rigid mounted the Softie, better design brains than ours would have pondered the issue for many years.
Old Jan 3, 2014 | 06:14 AM
Tom84FXST's Avatar
Tom84FXST
Old Jan 3, 2014 | 02:26 PM
traildog's Avatar
traildog
Spanners is always right (I Think). I like him.......
Old Jan 3, 2014 | 02:51 PM
Spanners39's Avatar
Spanners39
This guy mounted it from the rear tranny mount on bronze bushes so it only moves up and down and a rubber front mount....this will work until the bronze bushes wear and then it will be a problem.
Old Jan 3, 2014 | 04:50 PM
Tom84FXST's Avatar
Tom84FXST
Here's another:http://www.hotrod.com/featuredvehicl...idson_softail/
And another:http://www.barnettharley.com/barnett...l#.Usc8R7R-cVA
And here is a frame to do it...not too tuff
http://www.customcycledevelopments.com/fxrsoftail.htm
Softail frames for FXR drivetrains used to be quite common...couldn't be too hard to find one
Old Jan 3, 2014 | 05:33 PM
Spanners39's Avatar
Spanners39
The softail swingarm pivots on the gearbox as it does on a stock FXR;
That is the key to making it work....
Old Jan 3, 2014 | 06:24 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
You wouldn't by chance have any pictures of that would you?
I can't visualize that.
Old Jan 3, 2014 | 08:50 PM
Spanners39's Avatar
Spanners39
Look on the last of the links that were posted earlier. Basically its a Softie but the swingarm pivots off the tranny like a Dyna and not off the frame.....imagine a Road King that mated with a Softail.
