Oil flow/filter question
Old Feb 12, 2014 | 10:13 AM
falconbrother's Avatar
falconbrother
Default Oil flow/filter question
I'm sure I can look this up in my book. But I'm at work and just curious. Where is the filter in relation to the oil pump? Does oil go from the pump through the filter or, is it from the filter to the pump. Seems to make sense that it would go from the pump to the filter then to the engine but, I don't really know.
Years ago (way on back) I worked on recipricating aircraft engines, radial and horizontally opposed. I worked in the test cell and we always cut filters open on the engines that we ran in the test cell looking to see what kind of metal they were making. New ("0" hour) engines always make a little. As long as it's very small, and I mean very small flakes, like dust size, your fine. We could tell by what kind of metal it was as to the likely part that produced it.
Anyway, if something in a Harley BT started failing, or had failed, I'm guessing that the metal would hit the pump before it could be filtered. Is that correct?
Old Feb 12, 2014 | 10:19 AM
Lakerat's Avatar
Lakerat
Yup, goes through the pump before the filter.
Old Feb 12, 2014 | 10:34 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
It starts in the tank then goes to the pump then the engine then the filter then back to the tank.
Is that what you were looking for?
Old Feb 12, 2014 | 12:13 PM
Spanners39's Avatar
Spanners39
Evo has the filter on the return and twin cam has it on the feed.
OneBlackFly
Oil Archive (no new posts)
Jun 16, 2022 05:29 PM
wvhh
Ironhead
Oct 30, 2020 04:15 AM
Joe from So Cal
Oct 14, 2018 07:06 AM
evofloyd
Feb 24, 2011 11:13 AM
DeJavu
Custom Models
Aug 3, 2007 10:54 AM
