Here we go ! Another rebuild thread
Old Feb 28, 2014 | 07:52 PM
highbarst's Avatar
highbarst
Default Here we go ! Another rebuild thread
Due to the extreme cold this build has been getting farther behind than i would like but parts are finally coming home with the exception of my frame which should be done tomorrow. Will start assembling engine tomorrow reusing my HQ cam , Johnson high lift lifters , Weisco 10:1 pistons machined down to 9.7:1 .010 over , Daytona Twin Tech ignition and coil , S&S steel breather , Heads & intake blueprinted and flow benched within 2% . And to think this whole engine rebuild was just to cure some massive oil consumption.
Old Feb 28, 2014 | 08:28 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I'm not sure but I think there have been more rebuilds this winter than the last 3 combined!
Good luck with your build.
Old Mar 1, 2014 | 11:30 AM
tomfiii's Avatar
tomfiii
Take off those sharp edges on piston dome especially by valve recess .
Old Mar 1, 2014 | 01:25 PM
aces&8s's Avatar
aces&8s
Why would you shave a piston down from 10.1 to 9.7. ? Clearance? First time I have ever heard of that.
Old Mar 1, 2014 | 04:51 PM
johnjzjz's Avatar
johnjzjz
in a shop that is responsible for the work they do, will not with the gas we have today build a motor with high compression anything plus 9.5 to 1 will become a thing not if it does - if you have a long duration cam it cuts back on the static compression but puts the performance off till the revs are up high - not the way most drive and its not fun crusing as it lacks in power
the fix is a bigger motor 90 inches 100 inches is a start, you can get the power of compression with a increase of inches with out the issues the gas today has -- jz
Old Mar 1, 2014 | 04:54 PM
highbarst's Avatar
highbarst
Taking advise from machinist perfect comp. ratio for the cam and still be able to run 89 octane if need be .
Old Mar 1, 2014 | 04:59 PM
johnjzjz's Avatar
johnjzjz
you probly have a HQ 26 cam but thats my guess
Old Mar 1, 2014 | 05:08 PM
highbarst's Avatar
highbarst
HQ-24 Made a little progress this afternoon
Old Mar 1, 2014 | 05:10 PM
tmanbuckhunter's Avatar
tmanbuckhunter
Lookin good man. I bet that thing is gonna sound bad *** when you get it back together.
Old Mar 1, 2014 | 06:08 PM
johnjzjz's Avatar
johnjzjz
Attachment 361385
Attachment 361386
Attachment 361387
Attachment 361388
The HQ 24 has almost the same duration as the andrews 27 but it has lots of exhaust duration and will keep the oil and the motor cooler good choice --
