Single fire ignition.
Old Mar 12, 2014 | 11:57 AM
Dr.Hess's Avatar
Dr.Hess
Originally Posted by aces&8s
my Indy took off the VOES, said I didn't need it.
Found your problem.
Old Mar 12, 2014 | 01:00 PM
aces&8s's Avatar
aces&8s
Originally Posted by Dr.Hess
Found your problem.
I thought the VOES is only for retarding at lower RPM, not at 3000-3500? Will I be able to set my timing more advanced with the VOES restored?
Old Mar 12, 2014 | 01:16 PM
bluharley's Avatar
bluharley
"didn't need it?" Why was it designed with one if it didn't need it? Doesn't make sense, time for a new indie.
Old Mar 12, 2014 | 01:40 PM
aces&8s's Avatar
aces&8s
1997bagger, He does not use a VOES on his hot rod bagger either.
Old Mar 12, 2014 | 01:41 PM
bluharley's Avatar
bluharley
I'm all stock, so I'll keep my VOES.
Old Mar 12, 2014 | 01:53 PM
aces&8s's Avatar
aces&8s
Also,Ignition systems come with the option of using VOES or Not using VOES.
Old Mar 12, 2014 | 02:36 PM
Schex's Avatar
Schex
Dyna S does not use a VOES, it has advance weights and the advance is all in by 2000rpm.
Aces, you said your weights and springs are modified, so it may advance quicker than that or slower or how much it's advancing.
Might want to recheck the static timing to get a reference where the stock timing would be, mark your module, and go from there.
page 2
http://www.zodiac.nl/instructions/232290.pdf
or get a programmable ignition and cable & software, test and find out which canned map works best, then tweak that map where needed.
Just something else to think about,
I don't know if maybe that yost powertube has you a little lean in the mid range under hard accel,
a smaller air bleed jet will let the main jet come in sooner.
Old Mar 12, 2014 | 02:39 PM
Mcathcart's Avatar
Mcathcart
As "Pop" always told me, "Sonny Boy, If It Ain't Broke Don't Fix It". I also have a single fire on my Evo Bob-ster and I can't tell crap for difference between single or duel.
I've been looking at the VOES switch hanging on the Flat Black Bagger I'm building... Hummmmm?
Old Mar 12, 2014 | 02:41 PM
HGM's Avatar
HGM
Something to think about with the VOES, while I'm no expert on them, they rely on vacuum to operate and adjust your timing based on the vacuum produced in the intake. A strong engine with larger cam will not produce the same vacuum as stock. So, is it needed?? I guess it depends on your package, but it certainly needs to be calibrated for your engine package, if you have one. I tend to believe a good ignition system should do the job w/o it..
Old Mar 12, 2014 | 03:07 PM
aces&8s's Avatar
aces&8s
page 2
Thanks Schex, did not think about the Yost. All very good points you made.
Wish I could fly you in to fine tune this beast. Also my Indy used the medium springs so I should be OK there. Indy also said the advance is already done before 3000 rpm.
