Base gasket rebuild, thoughts?
Got the first head pulled apart today. Photos attached are from the front cylinder. Since I'm new to this level of detail on any engine, I was wondering if you all you pros out there could comment on a couple of things.
1) How do the valves look from below? There is a pic of the valves in place in the head. Should I replace them - and do the stuff that goes along with it - or can I just decarbonize them and put 'em back. I haven't done any measuring yet.
2) How does the piston look? I've seen a couple of pointers on how to tell wear by carbon pattern, but none of the seems to fit. Should I pull it and clean it - or do they get replaced?
3) This bike has 65K miles on it, and it looks like this is its first head job
4) I think the cylinder itself looks pretty good I am planning on replacing all three rings on both pistons since I have it apart. From the looks of the piston, should I do anything else? Hone it out?
5) Would it be worth it at this point to take the heads to a machine shop and have them cleaned and polished off, and do all this valve & honing work?
6) Here's what I'm replacing anyway: Fueling head studs and bolts (kit); James top-end gasket kit; Hayden Enterprises "The Oil Fix"; Andover Coils 12V coil; 8.8 mm Accel Custom Plug Wires; NGK Iridium IX plugs; Hastings standard size piston rings; and some other various & sundry items.
Thoughts are much appreciated!!
With that said I'd wanna know if it was smoking, burning oil, losing compression, etc.. If it were mine and had no issues before you tore it down and the cylinder walls looked good, pistons looked good, valves, etc.. I'd probably bolt it back together.
What I'm saying is, once you've covered the critical things everything else is gravy. I realize that some folks will feel differently. My philosophy is, if it ain't borke don't fix it (or it may really be broke). The stock evo, if properly jetted, etc.. will go a very long way without major work (save the stinking paper HD base gaskets).
Sounds like - at minimum - a hone and new rings?
You're assuming that whoever worked on it last got the cylinders right.
I would say to be safe go 10 over with new pistons and new rings.
Cometic makes a complete kit for redoing your top end.
I don't remember what it costs but it might be worth looking at compared to the cost of the James and Hayden set.
If you want that little extra oomph get rid of the stock cam and put in a better one. That will do a lot for your performance.
