Air Filter
Old Apr 8, 2014 | 02:58 PM
smoke71's Avatar
smoke71
6th Gear
Default Air Filter
When should i replace a cleanable air?
Old Apr 8, 2014 | 03:01 PM
jimbo285's Avatar
jimbo285
Do you mean when do you clean it?
Old Apr 8, 2014 | 03:31 PM
smoke71's Avatar
smoke71
6th Gear
nope i bought my bike a few months back and don't know how old it is. How long is there life span?
Old Apr 8, 2014 | 03:48 PM
grbrown's Avatar
grbrown
Some cleaners are washable, others are replaceable, so it would help if you can identify yours. What colour is the element, for example? If red/pink it is cleanable and the new oil to refresh it is red (K&N).
Old Apr 8, 2014 | 03:55 PM
smoke71's Avatar
smoke71
6th Gear
best i can tell it is a red element, but having said that when i took it off and cleaned it it still did not come very clean almost brown looking like it's oil stained
Old Apr 8, 2014 | 08:36 PM
Tony_N's Avatar
Tony_N
I clean my washable air filters by first spraying them down with either K&N Filter Cleaner or Castrol Super Clean and letting them sit for around 10 minutes. Then rinse well from the clean side out.
If the filter is still dirty I use a solution of about 8 ounces of Castrol Super Clean and water. I put the filter, dirty side down with just enough solution to keep the filter wet without totally submerging it. Let the filter sit in the solution for about an hour. Pull the filter out and then wash from the clean side out. The filter should now be clean as new.
Allow to dry completely, then oil and re-install.
Old Apr 8, 2014 | 09:21 PM
Beemervet's Avatar
Beemervet
DO NOT OVER OIL!! Only oil lightly until the element just turns red.
Old Apr 8, 2014 | 10:00 PM
Spanners39's Avatar
Spanners39
They basically last forever....
Old Apr 9, 2014 | 04:52 PM
smoke71's Avatar
smoke71
6th Gear
ok thanks guys
Old May 9, 2014 | 08:46 PM
AtticusFinch's Avatar
AtticusFinch
About how long does it take to dry?
