How to test ETS?
Old Jun 25, 2014 | 05:47 PM
johnod's Avatar
johnod
Default How to test ETS?
Not having the HD break out box or scanalyzer tools is there a way to test the ETS on a 97 flh?
I have the manual, finally, but all I see is tests with the tools.
The code/light gave no info.
Old Jun 26, 2014 | 03:22 PM
carlgrover's Avatar
carlgrover
Read through the "surging" thread in the EVO section. On about page 3 there is a chart showing voltage vs. temperature. You could hook up a voltmeter to the sensor and dunk it in a glass of water with a thermometer and a hot water kettle handy.
I might just try that the next time my ETS goes bad.
carl
Old Jun 26, 2014 | 04:02 PM
johnod's Avatar
johnod
carl
I dunno about putting voltage to something in water.
Old Jun 26, 2014 | 05:36 PM
larsfum's Avatar
larsfum
The temperature in the ETS chart refers to ambient air temperature. You do not need to remove it to test it.
Old Jun 26, 2014 | 05:43 PM
johnod's Avatar
johnod
So if I understand correctly resistance is checked between 2 terminals on sensor?
As I see it I can only measure this with the engine off.
I can't check resistance with voltage at the terminals.
Old Jun 27, 2014 | 07:47 AM
larsfum's Avatar
larsfum
Correct
champ198
Oct 12, 2010 01:06 AM
chiefbobo
Aug 9, 2010 09:02 AM
scubaharley
Aug 29, 2008 08:42 AM
dbcoooper
Welcome Area Only
Aug 6, 2008 06:40 PM
bucaman
Ironhead
Jul 15, 2008 04:47 AM
