Can the Evo manifold clamps be used, or do I need the S&S clamps?
There are 2 different diameter S&S manifolds. Older is smaller, newer is larger so the manifold "Flange Clamps" need to fit accordingly and tight so the intake seal wont squeeze out. I bought the new S&S E kit and all fit correctly. Call S&S, they will tell you the same thing.
I would also use the S&S intake seals for a better seal.
