my first Evo Harley
The OP traded straight up his 2005 for it, and I have zero idea what those are worth on the open market. I keep an eye on the EVO market, just for S&G's. So I have an idea what prices are being asked.
But that doesn't change the basic fact (like you posted), he traded a working bike for one that has 'issues'.
From his pics, I don't think it looks all that bad. But that's just from looking at the pics. Without doing some measuring, and some additional inspection, no one can really say.
However: Depending on what the OP's future plans might be for the bike, if he decides to keep it (new/bigger engine?), IMHO, I might just pull stuff out of the cam chest, pull the oil pump, clean everything up, douche the oil lines out, replace the bearing/cam and perhaps the breather (might as well), and ride it. IF, everything else checks out. Difficult to assess without physically being there.
But I've been known to gamble a bit.
what i did is what most would do tell the customer oil pump has gone away and we need replacement -- OK we installed a new pump and in doing so primed it and packed the gears in transmission assembly lube - WELL that did not fix it ( still only pumps oil in not out )
-- ok what happened is //// who ever did the top end had inadvertently let a piece of the wire harness covering fall into the open block, and it in turn with in a few days of riding was sucked into the oil passage and got stuck in the drilled hole in the sportys engine block stopping all return oil going into the return gearing - yep spilt the cases to find it
who pays for that job -- think about that for a moment - if you guessed i did your right
BUT do you tell the customer what happend and what you did to fix it --
And if you decide to cut your loses, i have cash in hand! Depending on how much. That bike is yelling for a stroker!
