Acceptable Gear Whine?
Old Aug 28, 2014 | 03:19 PM
boygenius's Avatar
boygenius
Default Acceptable Gear Whine?
finally finished up the ev27 install took out the adjustable pushrods /(now for sale if anyone wants em) and put in the stockers and the motor valvetrain noise is quite as a mouse , the lifters are new as is torrignton bearing and cam. rode the bike for about 15 minutes and it pulls phenomenal what a difference its like a different bike. however there is a small amount of gear whine from cam chest i uploaded a video, is this an acceptable level of noise ? will it cause major damage? i really dont wanna have to go back in there
VIDEO
Old Aug 28, 2014 | 03:23 PM
grbrown's Avatar
grbrown
Wink
Gears whine - it's what they do! It's humming to itself, full of the joys of life. You may just be listening to it more closely than you did before you made the change.....
Old Aug 28, 2014 | 05:36 PM
Throttle_Jockey's Avatar
Throttle_Jockey
What brand adjustable's?
Old Aug 28, 2014 | 05:44 PM
boygenius's Avatar
boygenius
rivera primo taper lite ez install pushrods
Old Aug 28, 2014 | 07:28 PM
Spanners39's Avatar
Spanners39
If you can hear it above the noise of the exhaust and the motor then its too tight and you need to install the stock gear wheel or an aftermarket undersized one.
I just did a gear drive conversion on a TC and the specs say 0.5 thou to 3 thou lash....this one had 0 thou and did not whine.
An audible whine when riding suggests clearance in the minus thou range which is why I always use the stock gear on an Evo...others will tell you to just ride it until the whine stops but they will be giving you bad advice.
Old Aug 28, 2014 | 07:40 PM
bigpup's Avatar
bigpup
I'd be interested in the pushrods. And your engine sounds good to me, my 94 custom sounded like that and I never had any problems with it.
Old Aug 28, 2014 | 08:19 PM
aces&8s's Avatar
aces&8s
Yep I hate whine unless its drinkable.
Old Aug 28, 2014 | 08:56 PM
apples402's Avatar
apples402
when you changed cams did you press your gear off and onto the new one? seems i remember you saying you did but if not any shop with a press can do this in about 5 minutes. lots of threads on the procedure but basically scribe marks at cam flat spot on your gear to use for alignment, press off, align and press back on. easy even for me.
electroach
Engine Mechanical Topics
15
Jan 5, 2023 08:46 PM
JohnSWA
Jun 30, 2013 08:09 PM
jkauffman86
EVO
22
Aug 16, 2012 04:39 PM
Z
Exhaust System Topics
Dec 3, 2009 05:42 PM
SmokinEd
Jun 1, 2008 10:07 PM
