Wrapping drag pipe baffles in fiberglass?
I attached a picture of the baffles:
Tom
[IMG]local://upfiles/18321/5A48B5F366DF4BD38B27DFD95D92A2FE.jpg[/IMG]
I might as well wrap the fiberglass on the bafflesand go for another test ride.
On a scale of 1 to 10, if a stock Harley exhaust sound level is a 5 and my setup without any baffles is a 10, I would like to get it down to between a 7 and 8.
Thanks,
Tom
The only other way I know of to adjust the sound just right is with slipon mufflers with adjustable baffles. Your sig shows the WB pipes and I think the turn down tips are removable. If so you could ad slipons with no problem. Baffles in most mufflers are multiple discs that are easily added and removed to give the desired sound or performance. With power cones and 1 3/4" drag pipes you probably are close to max power, any changes will affect that. Good luck, it's always a challenge to tweek things to be just right.
That is one of my problems. The hole in the straight pipe where you normally would bolta baffle to, is covered by the down tip and clamp, when they are in place. I have the baffles bolted in place now, since the tips are off. If I decide to permanently use these baffles, I will have to have them tack welded to hold them in place. Then I can take out the bolts and slip the tips back on. It seems like nothing goes easy.
I am trying my best, not to have to change exhaust systems. With my luck, if Iput on a new exhaust system, I would never get the bike dialed in to run as good as it does now.
Tom
