Need Help Please
Old Jan 17, 2008 | 03:53 PM
blacked out's Avatar
blacked out
Default Need Help Please
2008 Street Bob
If I go with the following set up will the download from the dealer be all I need ( they tell me the download is $250 )
Vance and Hines Big Radius
SE Heavy Breather Kit ( part # 43768-06 )
Thanks for all your help
P.s. Sorry bout the double post
Old Jan 17, 2008 | 04:06 PM
extech's Avatar
extech
Default RE: Need Help Please
Downloads are designed to be used with specific modifications, They do not offer one that is specific for the big radius.
You'd be much better off buying a power commander, they're adjustable, and they have some base maps you can download.
Old Jan 17, 2008 | 05:33 PM
glide's Avatar
glide
ORIGINAL: blacked out
2008 Street Bob
Download should be $150, that $250 if just the download is much too high. Call another dealer to verify this before giving them the extra $100
The download is for HD specific parts and would no doubt be off with those pipes.
Old Jan 18, 2008 | 10:59 AM
fxrp's Avatar
fxrp
Like extech said go with a PCIII. You can get one for about what you stealer quoted you for a stage I download.
Or drop the air cleaner and just install the pipes. Then you can run the stock map.
Old Jan 20, 2008 | 11:24 AM
08Fatty's Avatar
08Fatty
If pipes and A/C will be the only mods you plan on, take a look at the Terminal Velocity II. Its plug-n-play. Just install and ride and within about 50-75 miles it tunes itself. Its a little more pricey but no downloads or dyno time. I put mine on before I installed my pipes and it made a noticeable difference. Bike runs cooler with better throttle response and millage. PC III and fuel pak are good units, just a little more setup involved. This does the same thing with less time installing and making adjustments. Check them all out and make the choice that is right for you.
Old Jan 20, 2008 | 04:44 PM
tootal's Avatar
tootal
Go to http://www.nightrider.com/parts/and look at their plug and play. You retain your stock injection but this fools the computer into thinking your at 14.6:1 a/f ratio when your actually at 14.2:1. This will allow your engine to run cooler and the stock unit should compensate for the intake and exhaust changes as it does what the O2 sensors tell it.
Old Jan 20, 2008 | 09:34 PM
blacked out
Great info thanks guys
Old Jan 21, 2008 | 10:32 PM
cruiser85257's Avatar
cruiser85257
You can always go with the Vance & Hines Power Pack and save some money.
Mixter
Mar 23, 2010 12:39 PM
jb27
Mar 1, 2009 04:11 AM
BigRitchieKona
Apr 14, 2008 10:08 PM
blacked out
Jan 17, 2008 07:04 PM
GeezerGlider
May 31, 2007 10:40 PM
