HQ 107"
Old Jan 21, 2008 | 03:41 PM
stevek's Avatar
stevek
Default HQ 107"
I've seen a few referencesof to the HQ 107" build but, I haven't found it on the HQ website. What does it consist of?
Old Jan 21, 2008 | 03:45 PM
stevek's Avatar
stevek
Default RE: HQ 107"
Oh ya! I finally figured out how to post my signature! Now if I can figure out how to post a picture I'll really be techno savvy!
Old Jan 21, 2008 | 04:48 PM
PhilM's Avatar
PhilM
Default RE: HQ 107"
ORIGINAL: stevek
You're right! It's not listed.... It's basically the same as the 98" kit, but it requires a 4.375" crank.
Since ya gotta split the cases & replace the crank, you might wanna give serious consideration to the 113" kit. It uses the the same crank as the 103 / 107.
Old Jan 21, 2008 | 06:13 PM
huey408's Avatar
huey408
Default RE: HQ 107"
philm do the cases on the 96 inch motors have to be split with the 113 kit
Old Jan 21, 2008 | 06:16 PM
drdave's Avatar
drdave
Default RE: HQ 107"
not philm, but you will have to split the cases to make a 96" into a 113" - reason is you are going up to a 4.060 or 4.065 cylinder bore that requires boring the lower cases.
Old Jan 21, 2008 | 06:31 PM
PhilM's Avatar
PhilM
Default RE: HQ 107"
Dave is right......
The spigots on the bottom of the cylinders are a bit larger, so the case have to be bored a little.
If I were doing a 113 on a 96" motor, I would definitely want to have the crank serviced first, by someone like Darkhorse.You'll want to make sure it's true and then have it welded so it won't "sissor" on you. The 113 is too strong for that crank in standard form.
Old Jan 21, 2008 | 07:34 PM
bigjohn1percenter's Avatar
bigjohn1percenter
Default RE: HQ 107"
the 107 kit is listed on both the USA and the Canadian site.
Old Jan 22, 2008 | 02:32 PM
stevek's Avatar
stevek
Default RE: HQ 107"
philm, is the SE 4 3/8" crank assembly made by JIMS strong enough for the 113" application from HQ ?
Old Jan 22, 2008 | 04:23 PM
Dalton's Avatar
Dalton
Default RE: HQ 107"
Running a JIMs crank in my 120", definitely strong enough for the 113. There are a whole bunch of other considerationss once you start getting beyond the 103-107 builds. Cranks, crank bearings, case boring, piston oilers, crank balancing (JIMs are pretty good out of the box, but when John at Darkhorse gets done with them, they are a work of art), throttle bodies, injectors, exhaust and on and on.
If you do a HD 113 build, the bore on the jugs from HD is 4.060 and they do have taper.
HQ bores them new to 4.065 to remove all taper and supplies pistons to fit.
Old Jan 22, 2008 | 09:08 PM
nick@nite's Avatar
nick@nite
Default RE: HQ 107"
Checked out your myspace link, thanks for the David Allen Cole have not heard him since my army days......
Billerica Ma I bought my low rider there in 77, used to be called HD Freedom Center.
nick@nite
KaponeWKYA
May 1, 2022 05:52 PM
Roadglide@11
Jul 29, 2011 03:00 PM
wiseguy2day
Jul 21, 2008 09:14 PM
osolow
Jun 2, 2008 10:25 PM
outback2970
Mar 16, 2008 03:02 PM
