Compression Release
Old Feb 2, 2006 | 08:42 PM
FASTFXD's Avatar
FASTFXD
Default RE: Compression Release
Okay - and now here's a twist: unless you're building a very, mild build - why not go ahead and get your heads drilled out for them? You might upgrade sometime down the line anyway. Then - some guys like the unusual - and if that's your thing, why not go ahead and install a set? No one says you have to use them.
Old Feb 2, 2006 | 09:14 PM
tripl8's Avatar
tripl8
Any motor benefits from "lower" compression starting..if they,re off..tap em and pit the CR,s in.
Old Feb 3, 2006 | 11:08 AM
HDWRENCH's Avatar
HDWRENCH
No not really as if you do not have enough compression to close them. Keep your battery charged , clean connections and you will be fine.
Night Hog
Feb 5, 2010 02:09 PM
customsoftail200
29
Feb 2, 2010 02:24 PM
softail99custom
EVO
Jan 21, 2010 08:45 AM
sporty2003
Dec 21, 2007 10:41 AM
Tfrosst
Nov 4, 2007 08:50 PM
