Mm fuel inj to carb
Old Dec 7, 2008 | 07:26 PM
bxbutch's Avatar
bxbutch
Default Mm fuel inj to carb
Does anyone know of a kit to convert from mmfi to carb thanks butch
Old Dec 7, 2008 | 07:53 PM
kansasroadking's Avatar
kansasroadking
Default MM efi to carb
don't know of a ready-made kit, I have a list of what's needed that I copied from HQ a while back.... I tried to upload the pdf, but the forum only allows 19 kb the file is 99kb..
here's the list, the prices are probably no good anymore though... an you will need an ignition module like a DTT TC88.
Engine mount (with slot for choke) ……. 16315-99 $5.51
Choke cable ……. 29229-88B $8.80
Choke elbow ……. 27580-88 $2.18
Choke boot ……. 27582-88 $1.78
Intake manifold ……. 27613-99 $22.43
Manifold seals ……. 26995-86B $1.51 X 2
Seal ring (carb/manifold)…… 27002-89 $4.91
Ignition Harness ……. 32435-00 $104.43
Manifold sensor (MAP) ……. 32316-99 $26.95
Manifold sensor seal ……. 11291 $0.99
Retaining clip ……. 38723-99 $0.13
Retaining clip screw ……. 68042-99 $0.85
Stock Petcock- 61338-94D $53.00
Stock CV40 Carb- 27412-99D $168.00
MM EFI Tank Conversion from Pingel $40.00
K.
Old Dec 7, 2008 | 08:00 PM
Dsanchez's Avatar
Dsanchez
Default MM EFI to Carb
A buddy of mine did it to his 01 Ultra. Check this out...
http://www.hdtalking.com/jumpto.php?.../Carb/carb.htm
Old Dec 10, 2008 | 10:40 AM
HDWRENCH's Avatar
HDWRENCH
How did that AMP set up work out?? looks very simple as far as parts wise , any prices on that unit??
Old Jun 10, 2009 | 03:53 PM
killerbob's Avatar
killerbob
Anyone have part list for a EVO (1998 road king EFI)
Old Jun 10, 2009 | 04:32 PM
HDWRENCH's Avatar
HDWRENCH
I had a complete parts list somewhere of both evo and t/c conversion.
But you are going to need the carb, choke cable and bracket, intake, ign system ( after market is fine) , air cleaner, piggy back harness, pingel fuel adapter kit, some fule and maybe even a fuel filter beside the strainer on the pingel. I will see if I can locate the parts list. If not I know that I got the complete list of the web on this site or maybe the other big hd site.
M18A1
EVO
15
Sep 28, 2022 12:29 PM
01bagger10124
Apr 15, 2014 05:26 AM
kicnit
Mar 16, 2014 07:39 PM
guesscrazy
Jan 14, 2011 06:54 AM
schoney
May 19, 2007 11:47 AM
