Backfireing
Old Jul 3, 2006 | 02:42 PM
user 6485939's Avatar
user 6485939
Default Backfireing
I have a 04 FLHTCUI, fuel injected, its backfiring thru the air cleaner when just lightly on the throttle crusing, it feels like it sputters and misses but not when substansially on the throttle and when I let off its popping thru the tail pipes more than usual. What causes this?
Old Jul 3, 2006 | 03:50 PM
rh8234's Avatar
rh8234
Default RE: Backfireing
backfire thru carb while running easy and popping thru tailpipe on decel both are usually lean condition. If this just started and the bike had been running fine in the past, suspect possible intake leak. Also, have you changed to lower octane fuel? If so, that could cause symptoms like you describe.
Old Jul 3, 2006 | 03:56 PM
user 6485939
I tested it and dont believe I have an intake leak, how do I richen it up? Is this a adjustment that you need a computer program for?
Old Jul 3, 2006 | 04:15 PM
bountyhunter's Avatar
bountyhunter
Intake popping, a very brutal, sick, LEAN sound. Get it tuned!
Old Jul 3, 2006 | 06:23 PM
Biggzed's Avatar
Biggzed
As others have said, sounds lean. I would pull the plugs to see what they look like. They are probably really light colored (a real chalky white) indicating a lean condition. Ideally they should be light tan or a little darker. Check to make sure the ends aren't burnt off.
Are you running any kind of a tuning device (Power Commander, SERT, V&H Fuel Pack) now? What is the rest of your intake/exhaust combination? What are your future goals for engine work? Answering these questions will help you make a decision on a tuning device. It's possible you will see a difference in the conditions of the plugs for the front and rear cylinders. If that is the case, you will probably want to go with a PCIII or SERT. They allow more tuning than a Fuel Pack. Depends on what you have and what you want to do down the road.
BZ
Old Jul 3, 2006 | 11:28 PM
Bryan TTM's Avatar
Bryan TTM
start the bike and spray wd-40 around the intake...you'll know real quick if you have an intake leak
msulli
Oct 19, 2021 02:44 PM
wyotana
Aug 22, 2017 08:11 PM
Knights2TheEnd
Sep 25, 2012 06:00 AM
boogiejoe
Jan 7, 2010 08:21 AM
BadPiggy
Sep 4, 2007 06:26 PM
