If I were you and had to have adjustables, take out the aluminum and put screaming eagle adjustables in. They are made of steel and will last. I have personally seen, and heard of many more aluminum ones that have snapped of with very low miles. I just took out my Black widow cams and SE adjustables and replaced with SE 204 and stock push rods. Runs much better.
We load the lifter @ .140-.150".
Seems to keep thingsvery quiet.
Scott
So it really is a matter of experience that keeping a bit more pressure on the lifters helps keep things quiet?
I'm putting Rivera taperlites in on Monday/Tuesday when Brown brings them and was planning on using the 0.10 adjustment but also did experience the front intake coming loose on me with the SE adjustables so I'm about as nervous as a long tailed cat in a room full of rocking chairs....
I ran the Rivera Taperlites in my 120, after about 10k miles I had one shatter. Front intake shattered right at the top where the ball is pressed in. I am quite sure that this was most likely a one-off defect as I haven't heard of many other issues. I now run standard HD adjustables.
That being said, glad I carry tools with me cause when it shattered I was 4 states away at the top of a mountain. Had the old rod out, rocker box off and fished out the ball end and all buttoned up by the time help arrived with another pushrod.
I fought forever to keep my woods cam quiet in my evo, and did a bunch of adjusting and learning about the how the valvetrain works in a harley, and basically you have a .200 long cavity in the lifter, and the harley oiling system is to provide enough oil to fill .100 of the cavity, With that being said, and really, the oiling system being so poor, when you ruduece the amount of cavity (setting pushrods .150) to .50, it makes the it easier for the systme to fill, thats my understanding? could be wrong?
as far as the alum. p/r, they will work fine, got a set with 150k miles and rode hard and put up wet more times than i can shake a stick at.
the preload is .100 on the lifter. this is maintained to prevent the retainer ring in the lifter from being broken. the more aggressive cam profile will make more noise. as the cam goes around the peak, it will unload quicker than stock and cause some extra noise.
the oil flow through the lifter is not dependant upon the lifter stroke. matter of fact, i just about converted my hyd's to solids by using S&S spacers and run .025-.050 preload, only enough to quiten the engine. the reason is i run stealth and do not want a colapse lifter on my 7k+ run up.
the oil in the lifter is to remove and slack in the valve train. as a plus, with the spacers, i have virtually no bleed down so start ups are quick and quieter
