Ring Gap
Old Feb 28, 2010 | 09:52 PM
Gobike's Avatar
Gobike
Default Ring Gap
I am reassembling my engine after punching out the jugs to accept 107 ci pistons. Any sugggestions for ring gaps?
Old Mar 1, 2010 | 07:55 AM
rbabos's Avatar
rbabos
I'd just follow the specs provided for the pistons and rings. Can't go wrong with that.
Ron
Old Mar 1, 2010 | 07:54 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The Wiseco's have a different gap for the top, and second ring.
Don't know what piston you have though??
Scott
Old Mar 2, 2010 | 07:11 AM
Gobike's Avatar
Gobike
The local engine builder recommends 4 thousandths per inch of bore on the top ring, 4-5 thousandths per inch of bore on the second ring, and .015-.050 on the oil rings. Sound about right?
Old Mar 2, 2010 | 07:54 AM
Kingofcubes's Avatar
Kingofcubes
That will work fine.
Old Mar 2, 2010 | 07:58 AM
rbabos's Avatar
rbabos
For what it's worth as an example only, my CP pistons require Bore x .0045-.005 on the top ring, Bore x .005-.006 for the second ring, and minimum .015 for the oil rings. This is for Street/high performance. The second ring requires a touch more gap since it runs hotter than the top in just about any piston/ring fit. I'm sure your builder has a handle on all of this.
Ron
Old Mar 2, 2010 | 10:35 AM
HDWRENCH's Avatar
HDWRENCH
make sure the ring is cut squarely and de burred before install.
Old Mar 2, 2010 | 09:14 PM
Hillsidecycle.com
Sponsor
And whatever you do, DO NOT leave old parts, in the clients engine...
dyna50
Engine Mechanical Topics
28
Sep 10, 2023 12:06 PM
cthowards
Mar 5, 2016 11:54 AM
128auto
May 30, 2013 10:51 AM
harley_jeff
Apr 9, 2012 07:52 PM
CDN. RG
Nov 23, 2008 10:14 AM
