Another Oil Pump Question
https://www.hdforums.com/forum/6544859-post5.html
http://www.flyingwperformance.com/
For me, the se, Andrews or Herko kit.
The SE kit (25284-08) is a billet cam plate allows the use of stock cams, retains the use of the Morse (non roller) on the inner tensioner, converts both tensioners to hydraulic and includes the upgraded oil pump.
You can go to the Andrews website http://www.andrewsproducts.com/motor...nstall_Kit.htm
and get the list of the parts to upgrade with different parts. The difference is that the cam plate is stock, not billet, but the inner chain is a roller chain. This upgrade does require conversion cams but you said you were purchasing cams anyway.
You can buy the parts listed on the Andrews site from a discount H-D dealer, like Zanottis, for about $370. Everything is incuded except the fasteners that attach the tensioner blocke to the cam plate but you can get those from any hardware store. Or get the PNs from a late model parts manual and order them when you order the other parts.
Herko will sell you either kit and will include the conversion cams in the package as well.
