fuel problems
Old Oct 3, 2010 | 07:04 AM
bvpeletz's Avatar
bvpeletz
Stage IV
Default fuel problems
after using only 2.2 gallons out of a full tank my bike quits as if i am out of gas...fill it up and i can go till i use 2.2 gallons again...ther eis still fuel in tank but bike wont run once it uses that much fuel...it is a 97 heritage classic...
Old Oct 3, 2010 | 11:32 AM
mkguitar's Avatar
mkguitar
Possible that you have vapor lock?
When it quits, you open the tank, do you hear air "whoosh" ?
if you do, may need vented cap.
2.) this bike has split tanks connected by a hose, do you see equal amounts of fuel on both sides? is the level equalising through the hose?
3.) this is a carbed bike, yes? stock carb?
4.) any added fuel filter close to the cylinders ?? ( heat build up in filter, lines causing vapor lock.
5.) no change it you use reserve on petcock?
Mike
Old Oct 3, 2010 | 11:54 AM
bvpeletz's Avatar
bvpeletz
Stage IV
it has a stock carb and there is no added fuel filter... dont here a whoosh so dont think it is a vapour lock..what it does is after about ninety miles runs out then put it on reserve and get another twenty or so...i know there is still gas in there i should be able to go at least 180 miles on a tank as i am getting 45 to 50 miles per gallon
Old Oct 5, 2010 | 07:07 AM
bvpeletz's Avatar
bvpeletz
Stage IV
Well problem solved Actually the problem was my lack of knowledge about this bike I just bought When I was filling up I was only filling one side of tank as it has a crossover line between the two sides BUT the crossover line is so small that when u fill up the one side in like 30 seconds from a fuel pump there is only about a quart of gas going into the other half and I thought the whole tank was full but in reality I was only putting in half a tank full I didn't know u had to take both caps off and fill both sides.
Old Oct 5, 2010 | 10:13 PM
mkguitar's Avatar
mkguitar
nice!
a cheap fix.
each new ride has a learning curve
Mike
Old Oct 6, 2010 | 03:13 AM
95custmz's Avatar
95custmz
Doh!
just plain john
EVO
17
Apr 20, 2018 11:45 AM
Abandoned
Sep 7, 2016 08:41 AM
Barbarossa
Oct 23, 2013 09:35 PM
GoofySB
Jun 2, 2013 03:36 PM
Orca76
Jul 13, 2011 06:45 AM
