Power Problem
Old Dec 30, 2010 | 07:46 PM
VegasBigPapa's Avatar
VegasBigPapa
6th Gear
I was thinking the same. Going to get a dial indicator and check the cam timing at the rocker. I may call s&s Monday and see what the deal is with the gears. I have talked to 2 different dyno shops, 2 independent shop and 4 different HD dealer service guys, I haven't worked on alot of bike but I was an auto teck for 10 hrs, this has everyone baffled.
VBP
Old Dec 31, 2010 | 08:12 AM
shineybike's Avatar
shineybike
I had a similar dyno experience after having a 95" kit with andrews 26 cams installed, around 60 hp and 80 tq. My mechanic talked to the andrews tech support people and they told him the timing could be off a tooth. Sounded like the marks on the cams were either hard to see or hard to line up. They could not tell him which way to adjust the cam, it gets better in one direction and worse in the other. The mechanic shifted the one cam a tooth and I got 76/92 on the dyno. My guess is you are on the right track with the cam timing.
Old Dec 31, 2010 | 02:50 PM
VegasBigPapa
6th Gear
Shiney, do you know what your compression readings were before it was fixed? Mine was 165 back cylinder and 170 front.
VBP
Old Dec 31, 2010 | 03:06 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
You'll have a large difference in ccp when this occurs.
Scott
Old Jan 1, 2011 | 09:01 AM
shineybike's Avatar
shineybike
Sorry, I don't know what it was.
Old Jan 1, 2011 | 12:59 PM
VegasBigPapa
6th Gear
Hillside, can you clarify ccp? Is that an acronym for compression?
VBP
Old Jan 1, 2011 | 10:53 PM
djl's Avatar
djl
VBP
ccp = cranking compression
Old Jan 1, 2011 | 11:02 PM
VegasBigPapa
6th Gear
Thanks djl, I thought so but want to be clear....i am slow sometimes, haha!
VBP
artkrhymes
Feb 5, 2015 01:04 AM
jimwrench
May 18, 2014 11:46 AM
gnirtsnod
Jun 25, 2012 12:43 PM
RA51
Jan 25, 2012 09:27 AM
timberwolfz28
Aug 10, 2008 11:27 PM
