throttle/ idle cable help on efi
Old Jan 10, 2011 | 07:56 PM
ed gien's Avatar
ed gien
Default throttle/ idle cable help on efi
Can someone direct me or help me on a new throttle/idle cable install? Tried to install but cant get the two to sync. Also read about leaving slack in one line due to turning bars
Old Jan 10, 2011 | 10:12 PM
hatchetman's Avatar
hatchetman
Dont have my book with me but I do remember that for 1 of the cables, you have the throttle pinned.
I will see if I can find the info!
Hatch.
Old Jan 10, 2011 | 10:22 PM
slyder's Avatar
slyder
You pin the throttle open then adjust the throttle cable till the lever on the butterflies hits its stop. Then you release the throttle and adjust the idle. Dont over tighten the idle or it will cause a bind.
Old Jan 10, 2011 | 10:25 PM
hatchetman's Avatar
hatchetman
What he said! Thank's dude!!!
Hatch.
Old Jan 10, 2011 | 11:09 PM
Kowan's Avatar
Kowan
Throttle is adjusted as they said. Wheel pointed straight ahead and full throttle watching as it just touches the cam stop and back it off half a turn.
Wheel turned full right, adjust idle cable until the spring just touches. Tighten em up and replace the weather boot.
The throttle should snap back to idle testing full right turn/left turn.
Old Jan 11, 2011 | 06:55 AM
ed gien's Avatar
ed gien
O.P. Thanks guys! This will help alot. One question, Where is the cam stop?
Old Jan 11, 2011 | 07:11 AM
Kowan's Avatar
Kowan
My manual in in the garage, but the cam stop is to the rear of the FI throttle body. As you rotate the throttle, you'll see it come up against the stop if you watch the cable mount.
Old Jan 11, 2011 | 08:06 AM
eleft's Avatar
eleft
Try this
http://docs.google.com/viewer?a=v&q=...Su6ri_QGBH0RKg
Al
Old Jan 11, 2011 | 05:59 PM
ed gien's Avatar
ed gien
thanks eleft, have jury duty tomoorow and this will be a little time waster!
JustDave71
Nov 8, 2014 04:20 AM
Denis1227
General Topics/Tech Tips
Sep 7, 2014 10:02 PM
Hazim
Oct 29, 2011 01:31 PM
pheur
Aug 12, 2011 08:30 PM
ed gien
Jan 14, 2011 05:57 PM
