Exhaust leak at head pipe to head connection
Old Aug 8, 2011 | 11:13 PM
CT-Bagger's Avatar
CT-Bagger
Default Exhaust leak at head pipe to head connection
I am going to change my head pipes again as I had an exhaust leak on the rear cylinder where the pipes bolt to the head and decided to change from V&H power duals to V&H dresser duals.
Is there a way of bolting them up avoiding the possibility of an exhaust leak again?
Old Aug 9, 2011 | 01:05 PM
nevil's Avatar
nevil
New gaskets would be good, but I'm sure you have that covered. I can only tell you what the Dyna shop manual says. On the front, finger tighten lower nut, then torque the top one 9-18 in lbs. Torque the bottom one to 60-80 in lbs (not sure if yours the same), then torque the top to spec. Repeat for the rear. Do this before you tackle the rest of the system.
I run mine for a couple of miles to heat up, let them cool down and check the torque. When done, I double nut the studs just so they won't back off.
Old Aug 9, 2011 | 03:27 PM
djl's Avatar
djl
Good advice. Get the SE SS gaskets not the OEM ones and follow the above sequence.
Wally
Apr 26, 2022 08:55 PM
DaleMc0622
22
Nov 19, 2018 09:32 PM
OneTrashyDyna
Jul 8, 2015 08:45 PM
danzio
Sep 5, 2012 10:10 PM
Rickr01
May 19, 2012 09:24 AM
