Basic cam install question
Old May 10, 2013 | 01:25 AM
msocko3's Avatar
msocko3
Originally Posted by target64
after I install the tw 555 cams after the first roadtest I knew it needed more compression it had a soft spot between 2000 --- 2800 rpms after that it pulls like hell.
Shhh.... Don't tell that to all the trikes I know of who are running the TW555 as a simple bolt in. When we put my dads trike on the same dyno as the previous year when he had SE255's in we were surprised to see the TW555 pulling just as early and making more torque as the 255's. I had a set in the 2010 trike I owned and I pulled a trailer and never lacked low end grunt. IMO exhaust makes a big difference when it comes to how early or late the torque comes in. Most of the trikes I know of are either running factory head pipes with small baffle slip ons or a Fuelmoto Jackpot head pipe with slip ons.
Old May 10, 2013 | 04:26 AM
target64's Avatar
target64
I had two exhaust to play with v&h big shots and the bassani 2 into 1 and there was that lag at 2000--2800 that was not there with the stock cams. the stock cams had a smooth power all the way through the power band. after talking with several builders they suggested to bring compression up to where that came would run better. did the head work and the lag was gone and a lot more power.
Old May 11, 2013 | 06:44 PM
SniperDude's Avatar
SniperDude
well my cams get here on tuesday.
besides the cam bearing removal/install tool and basic tools and assembly lube.
I have torque wrenches and the gaskets as well.
Do I need anything specific?
Old May 12, 2013 | 07:20 AM
junglejoe's Avatar
junglejoe
you just about got it.....I don't know if those newer ones use a shim or not..
chiefy305
Nov 29, 2020 08:09 AM
barrygreen
Engine Mechanical Topics
21
Oct 17, 2017 09:41 PM
Madcop
Aug 14, 2014 09:52 PM
trnewman
Mar 26, 2013 04:29 AM
hddave2
Jun 10, 2009 03:56 PM
