tw 26 cam install
Old Oct 16, 2013 | 08:43 PM
bigdog1949's Avatar
bigdog1949
Default tw 26 cam install
put in tw26 cam,used SE adj p/r,runs great, but lifters are noisy ,had adj p/r in with stock lifters,where quiet,did the 2.5 turns went 1/4 turn more,no change,are the Andrews 26 cams noisy ??,picked up comp cams lifters 875-1,will be doin the change next week,hope there quiet !!!,any feedback
would be appreciated !!
02 88 flhtc,excellent oil pressure
Old Oct 17, 2013 | 07:42 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
24 TPI pushrod............3.3 turns.
32 TPI pushrod............4.5 turns.
Loads the lifter to .140" which results in quiet operation even at warm temps.
Scott
Old Oct 17, 2013 | 07:55 AM
bigdog1949's Avatar
bigdog1949
Default tw26 cam
Scott
thanks scott !!
Old Oct 17, 2013 | 01:52 PM
Hillsidecycle.com
Sponsor
Yes sir.
Old Oct 17, 2013 | 10:27 PM
bigdog1949's Avatar
bigdog1949
Default lifters
Yes sir.
forgot to ask, that goes for the compcams lifters 875-1 ??
Old Oct 18, 2013 | 11:02 AM
djl's Avatar
djl
Yes, lifters all have the same .200" travel; the pushrod TPI will determine the number of turns required to set preload at .140". Your pushrods, IIRC, at 32TPI.
EDIT: Bob is right; the 875-1 lifters are travel limited.
Old Oct 18, 2013 | 08:40 PM
BVBOB's Avatar
BVBOB
850 comp cams have 200 thou travel, 875's have substantially less due to the thicker top clip, might want to check this out before you try to load them 140 thou.
Old Oct 19, 2013 | 06:29 AM
Hillsidecycle.com
Sponsor
We stay with S&S lifters here, and no guess work as to plunger travel, or quality.
Makes it simple.
Scott
Mattster
Nov 29, 2015 08:45 AM
Stl.glider
Jan 4, 2013 08:45 AM
Molarman
Dec 26, 2012 05:32 PM
SecondChance!!
Aug 3, 2012 09:58 PM
heavypic
Jul 20, 2009 05:40 PM
