Engine Mod Time!
I haven't posted in a while cause I didn't really have much to talk about! NOW THOUGH......I got plenty.
So here's the plan on my 06 Heritage....
I think I'm gonna just go ahead and get the drop in 97ci cylinder set from S&S. The stock cylinders can only be bored to a 95ci and since I'm gonna be running a set of S&S 585's and the price difference between punching to a 95ci and just dropping thy 97 in was about 200.00. If it's that close....bigger is better imo. Of course that's not all..... I'll be swapping the stock carb with an S&S Super E, adjustable push rods, heavier valve springs, will either deck the cylinder or mill the stock heads (if not enough clearance in cylinder) to get comp up to around 10-10.5 : 1.
I'm running Rhinehart Duals right now which WILL be swapped for a Drago's Bike Works CSC 2 into 1 down the line (funds run out quick! ).
I don't do alot of top end roaring but I DEFINATELY enjoy the head snap getting to the speed limit !!
Hope you are all well and the New Year has started off right !!
-Red
-Red
Compete kits with Cometic gaskets, ring end gaps set, and installed on the pistons.
Also you'll want to at least install larger valves, with a precision valve job, and port-match the heads to the intake manifold I.D of that S&S intake manifold.
We offer our own progressive wound spring kit for that, as well as other spring kits in stock.
A fully ported head is really the way to go.
Compression for that .585 needs to be 10.5-10.7 cr.
Another aid will be to install a Thunderjet in that carb, and a DTT ignition to control the spark event.
With that said, it'll run VERY well.
Scott
So am I being mis-informed here?
Wiseco manufactures those pistons for us.
Been boring those 88's now for almost 8 years, and HD cylinders for over 2 1/2 decades, and have recieved feedback from many folks that have 40,000, and 50,000 miles on 'em.
No worries whatsoever.
Scott
