Header pipes causing check engine light
Old Apr 25, 2014 | 11:46 AM
kylewetzel's Avatar
kylewetzel
5th Gear
Default Header pipes causing check engine light
Please help! I'm new to this Forum, and I'm trying to troubleshoot a problem:
I own a 2014 Iron 883 and I just replaced the stock header pipes with the jet black HD header pipes (same stock exhaust system, just a different look). However, now the "check engine" light comes on- and stays on- when the bike is running.
Is this the O2 sensor on one of the pipes? I double checked both pipes and the O2 sensors seem to be on pretty tight. Any ideas to get this resolved?
Also, is it regular for the new header pipes to give off a different smell, as if they're getting broken in?
Old Apr 27, 2014 | 05:16 AM
target64's Avatar
target64
did you swap out the original o2 sensors to the new pipe ?? not sure if the new pipe came with them in it. you want to unplug the o2 sensors and take a good look at the terminals make sure you did not bend them when you disconnected them prior. or make sure one of them is not backed out which would not make good contact. on both connectors and look close at the ones on the bikes harness for the same . the smell is normal on the new pipe
Old Apr 27, 2014 | 09:56 AM
kylewetzel's Avatar
kylewetzel
5th Gear
At this point, I'm 99% sure that the rear O2 sensor was compromised. I've looked up a few different replacement O2 sensors- is there a certain brand I should shop for or stay away from?
Old Apr 27, 2014 | 09:09 PM
target64's Avatar
target64
where is the original pipe with the o2 sensors ??
rIsK
Feb 8, 2015 02:21 PM
DynaJ
Feb 6, 2014 04:14 AM
ghoticov
Sep 10, 2012 06:47 PM
whateva
Jun 15, 2007 08:16 PM
waterman7474
Sep 21, 2006 11:37 AM
