Basic routine maintenance tools 101
Old Sep 12, 2005 | 04:07 PM
oldgeezer's Avatar
oldgeezer
Default RE: Basic routine maintenance tools 101
I got a set of torx and allen's that would fit my 3/8" drive socket. Sometimes, you have to short stroke bolts and being able to use a socket wrench saves a ton of time. Get a couple of replacement bulbs and fuses and carry them on your bike somewhere. Also, I'd suggest getting a small flashlight to carry as well.
Old Sep 12, 2005 | 04:09 PM
Tripper's Avatar
Tripper
Did anybody mention a 5/8" sparkplug socket?
Old Sep 12, 2005 | 04:16 PM
ecvjohn's Avatar
ecvjohn
ORIGINAL: dert
I would dispose of anything that had a torx head and replace with allen heads,chrome steel.Namely the primary cover and the inspection cover .They look better and are easier to work with.Ive done this on both my bikes after ruining the torx heads .Get only the best tools ..Ive obtained all mine through Sears sales .Somewhere you will need a 10mm wrench,cant remember for which area though.
My battery terminals are 10mm.
Old Sep 12, 2005 | 04:56 PM
DGlide04's Avatar
DGlide04
Craftsman gets my vote also, but watch the in/lbs. torque wrench. I was going to purchase one, but the lowest reading on the scale was till higher than some of the torque values for the various nuts and sockets on the bike. As far as T-27 Torx bits go, I found an entire card of them, I think there were 6 in all at Home Depot in the tool department where they have the individual screwdriver bits. T-27 is found on the derby cover, I think the timer cover and handlebar switches. Using a too small or too large Torx makes things a real mess.
Old Sep 12, 2005 | 07:47 PM
STYX's Avatar
STYX
Why is that?????
ORIGINAL: ecvjohn
ORIGINAL: dert
Old Sep 12, 2005 | 09:54 PM
ecvjohn's Avatar
ecvjohn
ORIGINAL: STYX
Why is that?????
ORIGINAL: ecvjohn
ORIGINAL: dert
If your asking about Torx, they can be a major PITA to work with, allens are more user friendly. If your asking about the 10mm, don't know it came that way.
Old Sep 13, 2005 | 03:01 AM
Ronster98's Avatar
Ronster98
I have a Craftsman torque wrench that ranges from 10 t 75 ft. lbs. There are some torque specs that call for inch lbs., but I just wing it there. I have a Torx socket set that went up to T-50 and found out that I needed a T-55 at some point. I also have a hex socket set because a simple Allen wrench set won't do if you need to tighten down to a specific torque setting. I've always had a s*** load of tools.
Like my S&W 44 Magnum and Walther P99, they can have my tools when they pry them from my cold dead fingers!!!
LordLoco817
General Topics/Tech Tips
Apr 10, 2017 11:01 AM
Skippy97
Feb 8, 2013 08:23 AM
newbie wrencher
Jan 14, 2012 11:32 AM
street2007bob
Feb 12, 2008 11:19 AM
vladt
Nov 30, 2007 06:46 AM
