Tie down bracket?
Old May 21, 2015 | 11:12 AM
jram116's Avatar
jram116
1st Gear
Default Tie down bracket?
Just installed tie down bracket on 15 Electra Glide Limited. Used the stock studs and acorn nuts to secure it, instead of the kit supplied bolt. Seems to be secure, has anyone done this and had any issues with the bracket while hauling their bike? The only thing I can see might be a problem, is if the nut isn't strong enough to endure the strain of the long haul. I would ride the bike to Texas each winter, but haven't figured out how to while towing a 5th wheel toy hauler.
Old May 21, 2015 | 11:17 AM
warprints's Avatar
warprints
What are you calling the studs and the nut? Doesn't the kit come with the brackets and bolts (what you call studs?) only? The nut would just be reused.
Old May 21, 2015 | 12:11 PM
jram116's Avatar
jram116
1st Gear
The kit comes with 4 bolts and washers no nuts. The bolts from the kit has an allen head, screws into the fork so there is no nut just an ugly looking galvanized allen head showing. I like the stock chrome better, but wasn't sure of the strength of the stock chrome nut.
Old May 21, 2015 | 12:34 PM
RollaMo's Avatar
RollaMo
When I installed mine, I used the original studs and acorn nuts.
It just looked nicer.
Then I got to thinking about why did they supply new hardware?
Well, I talked myself into re-doing it using the supplied hardware in the kit.
Although, I think it will work just as well using the original studs and acorn nuts.
I have read where others here kept the factory hardware as you did.
Old May 25, 2015 | 03:48 PM
hutch4's Avatar
hutch4
Ai installed the same brackets on my 2014 CVO Limited. I installed these in December of 2013. I used the original studs and accron nuts just because of the looks. I have trailered the bike to Flordia last winter and Texas this winter. I used these brackets to tie the bike down and got along fine. Hutch
Old May 25, 2015 | 04:20 PM
jram116's Avatar
jram116
1st Gear
Thanks all for the responses. I checked with the service and parts guys at my Harley dealer. They said they install either way depending on what the customer wants, and have not heard of any problems.
Old May 25, 2015 | 10:00 PM
Hocus-Pocus's Avatar
Hocus-Pocus
Not sure what you're calling tie down brackets. I've always just run the tie down straps up to the handle bars.
Old May 26, 2015 | 07:53 AM
From_Behind's Avatar
From_Behind
I think he's referring to these Harley Davidson tie-down brackets.
Right here.
monster715
Mar 18, 2014 10:09 PM
blueridge
Jun 3, 2013 06:41 PM
Catfish57
Mar 14, 2009 08:09 PM
Rob2002
Sep 25, 2008 08:23 PM
Dynamite17
Feb 2, 2008 05:51 PM
