docking hardware kit questions
Old Jun 1, 2013 | 07:39 PM
blueridge's Avatar
blueridge
Default docking hardware kit questions
I got a question. I have the docking HW kit and the directional light kit. Was wondering why we have another bracket in the docking HW kit? does this replace the bracket already on the bike. Does the bracket go inside of the fender? I am asking because I thought I saw a bike in the dealership with a bracket outside the fender (and maybe it had another bracket inside the fender?).
The only reason I can see why there is another bracket in the docking HW kit is because the lights will stick out more so the bracket facilitates that?
Do I take off the standard bracket and use the bracket from the docking HW kit?
Old Jun 1, 2013 | 07:58 PM
chris h.'s Avatar
chris h.
The bracket goes on the inside, it has to do with how the turn signals are mounted and how the bolt/wires are routed I believe. You will have to use the brackets that come with the kit.
Old Jun 1, 2013 | 08:32 PM
Qdog002's Avatar
Qdog002
What`s the part number of the kit?
Old Jun 1, 2013 | 08:35 PM
TomboAT65's Avatar
TomboAT65
It's also stiffer than the stock one. I used it when I did mine.
Old Jun 2, 2013 | 06:44 AM
blueridge's Avatar
blueridge
Part Number is 53797-09 and you also need to get the Relocation kit and this depends if you are going to get saddle bags or not.
Old Jun 2, 2013 | 08:22 AM
Chase1961's Avatar
Chase1961
Use the bracket that came with the kit.
Old Jun 2, 2013 | 08:38 AM
maddghost's Avatar
maddghost
I know which part you mean. I think they are of equal strength. just a cheap piece of nickel plated tin with a couple of bolts welded on. Remove the old ones and compare them, choose whichever the welds look better. If your like me you won't see much difference at all. I had the docking replacement hardware on there and the weld cracked off of one of the bolts. So I used the stock bracket to replace it. never broke again
Old Jun 3, 2013 | 06:41 PM
blueridge's Avatar
blueridge
Well...I had to come back and post that I broke the rear part of the bracket when I installed the stalk. I looked at the other one that came with the kit and yeah its a tin piece with the bolt weld in two places. To me the stock bracket looks much better. From what I can see...they both look the same and actually the stock bracket looks better made. If you are using the stock bracket then that is what I will do.
Don't understand why Harley would make us buy these additional brackets when it is really not needed. However I do not think I need to torgue too tight too. It says to torque 12 ft-lbs or 16-24 Nm and since I do not have the right attachment to tight this up I will just do by hand. I think the loctite will take care of this not coming loose.
Bet this cheap bracket was made in China lol.
slag1sh
Jul 18, 2017 02:20 PM
durtyburt
Mar 21, 2012 07:14 AM
topdwg
Jun 18, 2011 06:04 AM
BlockHead96
Jan 29, 2009 04:10 PM
Rodent
Nov 25, 2007 11:38 AM
