caution! Jackpot headers
Old Jun 27, 2015 | 05:42 AM
Joe Dirt 14's Avatar
Joe Dirt 14
Default caution! Jackpot headers
I done stage 1 on my ultra limited this spring and went with the jackpot headers. I saw a post on here where Jamie of fuel moto said that the outside diameter of this header was the same size of the outside diameter of the factory exhaust gaskets. This was the first time I had replaced headers on a bike and Jamie said they would work with factory gaskets. They just mash up into the gaskets being that they are the same size. So if you use factory gaskets you can forget about torqueing the flanges back down to specs. had I known this ahead of time I would have used the gaskets that fits the header so I could have got my torque specs. But all in all I like the headers. Hope this helps some one if they are thinking about using the jack pot headers. CHANGE THE GASKETS!
Old Jun 27, 2015 | 06:36 AM
ngshop's Avatar
ngshop
So if stock gaskets are an issue to you, what gaskets do you recommend? I used factory gaskets, not screamin' eagle gaskets in 2011 when I did mine.
Old Jun 27, 2015 | 06:58 AM
Iceman24's Avatar
Iceman24
Stock exhaust gaskets are metal "crush" gaskets and must be replaced vs. reused...did you replace yours when installing this new header? If so, they'll collapse as you torque the flange bolts down.
Old Jun 27, 2015 | 07:20 AM
sixguns's Avatar
sixguns
I run the jackpot 2/1/2 header with the factory gaskets and the factory torque, no problemos.
Old Jun 27, 2015 | 08:07 AM
JMC22's Avatar
JMC22
There are two types of exhaust gaskets - tapered and non-tampered - make sure you are using the correct ones for your pipes....
Secondly, the fit trying to get the gaskets into your heads is a tight fit - make sure to take your time as not to pinch them....
Old Jun 27, 2015 | 08:34 AM
Joe Dirt 14
fuel moto offers a gasket for the header. I got mine sealed up against the stock gaskets. The jack pot headers are not tapered like the factory headers. The gasket from fuel moto has a shoulder on it that sets against pipe and head.
Old Jun 27, 2015 | 08:53 AM
1flhtk4me's Avatar
1flhtk4me
My 2011 has had the FM catless pipe on for 26,000 miles with the original factory gaskets.
Old Jun 27, 2015 | 02:15 PM
ngshop's Avatar
ngshop
Good to know Fuel Moto has their own gaskets now. They either did not offer them when I got my stainless 2-1-2 ceramic coated or had not started producing them. At that time they advised to use the stock H-D, not screamin' eagle gaskets. Good to know, that when they come off I will try their gaskets. 58k on current headers and gasket.
Old Jun 28, 2015 | 02:21 AM
NoCoLoco's Avatar
NoCoLoco
Between OEM gaskets and Jackpots, I would use whichever ones cost less... as they both accomplish the same thing!
Old Jun 28, 2015 | 02:29 AM
'Ol dirty biker's Avatar
'Ol dirty biker
For the minimal cost of gaskets why would you NOT replace them? Cheap insurance
emerican19
Feb 1, 2013 10:01 AM
jm04
May 31, 2011 03:09 AM
Rickr01
May 7, 2011 08:20 PM
red.heritage
May 27, 2010 11:26 PM
snooper0069
Apr 12, 2009 01:00 PM
