Tapping the knowledge pool
Old May 31, 2016 | 07:43 AM
Sid1200's Avatar
Sid1200
Default Tapping the knowledge pool
A friend has a 09 Sporster low 883. She went to start it last night and no go. She does leave it on the tender and the battery was new last year. All lights come on and it primes but then when she hits start...nothing. No sounds no clicking nothing. She has tried both fobs and the red key blinks.
Any ideas???
Thanks in advance for any help and ideas.
Old May 31, 2016 | 08:37 AM
Donnybrook's Avatar
Donnybrook
The same thing happened with my wife's 07 883. It was a starter micro relay. The Drag Specialties part number is DS-325849. Hope this helps. It was only an $8.00 part at my Indy.
Old May 31, 2016 | 09:40 AM
WildBill_50's Avatar
WildBill_50
Have you checked the kill switch? I know this sounds crazy but I have seen it all to often. I went over to a friend of mine on day and he had his bike apart and his meter out checking wires and anything else he could think of. I asked him what he was doing and he said it won't start it won't even turn over. I looked over at his kill switch and sure enough it was on. Switched it off and the bike fired right up. He wasn't the first person to do that either.
Old May 31, 2016 | 09:46 AM
Smokey Stover's Avatar
Smokey Stover
Ha, Yea I'll admit it, Happend once to me. Don't know how run switch got switched off. I'm one of the ones that never use it. Took me about ten minutes to figure it out after checking fuses lol.
Old May 31, 2016 | 09:48 AM
Kayakguy's Avatar
Kayakguy
More bikes have probably failed to start because of that pesky kill switch than anything. But no one will admit to it!
Alright, I will admit to being stymied for a minute or two before. But in all fairness I turn my bike off with the key and had hit the kill switch by accident. I have never gone as far as breaking out tools...yet.
Old May 31, 2016 | 10:18 AM
14GuineaPig's Avatar
14GuineaPig
Did she try her PIN to disarm the security?
Old May 31, 2016 | 10:57 AM
Axis39's Avatar
Axis39
A battery tender will not charge a battery sufficiently to start a bike... Might not even charge it enough to light lights.
Try jumping it, or putting it on a regular charger.
Old May 31, 2016 | 10:59 AM
IdahoHacker's Avatar
IdahoHacker
Originally Posted by Axis39
A battery tender will not charge a battery sufficiently to start a bike... Might not even charge it enough to light lights...
It most certainly will. That is, obviously, the entire point of keeping a bike on the battery tender.
So it will start.
For the OP: I'll add to check the kill switch.
BTDT.
Old May 31, 2016 | 11:29 AM
decencyxdefied's Avatar
decencyxdefied
Sorta the same thing happened to my buddy and we tracked it down to the turn signal module I believe
Old May 31, 2016 | 11:35 AM
Rocker NH's Avatar
Rocker NH
Put a new battery in the key fob
