Counter-steering
Old Oct 26, 2016 | 09:36 AM
  #1121
MikerR1's Avatar
MikerR1
Originally Posted by FNGonaRK
Back pressure. Wow.
The back pressure is caused by the wheel wanting to straighten itself out.
There are two ways to relieve that pressure...(I am sure someone will correct me if I am wrong)
1. take your hands off the bar
or , and this is the important one,
2. turn the wheel the other way and into the turn so the wheel is pointing in the direction you are going. If your lean angle is right for your speed (stable lean angle) the back pressure should be gone, if not you are going to have to counter-steer some more.
I think the reason people have to counter-steer through a curve is because their speed is to high. If you are counter-steering through the curve you did not slow down enough before you entered the turn. As the video of the motorcycle racer shows, even the racers do not intend to counter-steer through the curve. They counter-steer before the turn and get into position and steer into the turn.
https://www.youtube.com/watch?v=iDeSn_QJ_sI#t=13m30s
"You lift your body and shift you weight to the right, when you do that, you automatically press on your right hand which makes the bike counter-steer, which is making the bike tip over, and once you get down there and into position you stop the counter-steer."
Old Oct 26, 2016 | 09:42 AM
  #1122
rjg883c's Avatar
rjg883c
Originally Posted by MikerR1
when you are in an unstable lean you have to hold backpressure on the bars to keep your lean angle stable.
If by 'unstable lean' you mean centrifugal force is attempting to push the scooter to the outside of the turn, that is what some of us having been posting. And isn't it amazing that the wheel isn't pointed in the direction of the turn, but is actually pointed, slightly, away from that direction?
  #1123
keith_stepp's Avatar
keith_stepp
Yes I did try this.
No you didn't.
Old Oct 26, 2016 | 09:43 AM
  #1124
LoneRiderFLH's Avatar
LoneRiderFLH
I'm so confused. Went for a ride and froze on first turn. Walked the bike home. Thanks Miker- not
Old Oct 26, 2016 | 09:49 AM
  #1125
MikerR1's Avatar
MikerR1
According to Keith Code we should not be riding by "instincts". He says that nothing about riding a motorcycle is "instinctive". As an example, most people are afraid to lean, but leaning may save your life.
Keith Code says that we need to "ride with understanding"
Here is Keith Code video saying this...
The art of cornering
https://www.youtube.com/watch?v=A6jH9kXFhDM#t=1m46s
Old Oct 26, 2016 | 09:55 AM
  #1126
JMC22's Avatar
JMC22
Let me get this right, the OP comes on the HD Forum inquiring about counter-steering so he can better understand, yet he has disagreed with just about every single member here because he believes Youtube on the internet has better info....
I'm starting to think the OP might even be too stupid to even be a guest on the Jerry Springer show....
Old Oct 26, 2016 | 09:57 AM
  #1127
keith_stepp
According to Keith Code...
...people who do not own or ride motorcycles should not try and explain how to counter-steer to people who do own and ride motorcycles.
Old Oct 26, 2016 | 09:58 AM
  #1128
Uncle Larry's Avatar
Uncle Larry
I'm starting to think the OP might even be too much stupid for even being a guest on the Jerry Springer show....
too much stupidity even for a Jerry Springer show ... Ouch ... That'd be a new low. :>)
  #1129
MikerR1's Avatar
MikerR1
Well I guess it means I'm qualified.
Old Oct 26, 2016 | 10:00 AM
  #1130
chuckw2's Avatar
chuckw2
You don't steer into the turn at any speed over 10 or 15 mph. You counter steer, then maintain that line. Stop it already. Go watch and LISTEN to that Keith Code video.
