Fluid change, now difficult neutral
Old Nov 6, 2016 | 02:01 AM
  #41
RomeoTango's Avatar
RomeoTango
Originally Posted by perki48
Ask her if you can use her "Turkey Baster" to pull out the excess oil, see how distracted she gets..................LOL
Haha! And here I was just gonna send her shopping!
Old Nov 6, 2016 | 09:37 AM
  #42
hardheaded's Avatar
hardheaded
Originally Posted by Bricklayer
Tell that to my 14 RoadKing.
yes , the roadking still had a cable in 14, but we are not talking about a roadking here.
Old Nov 11, 2016 | 12:24 PM
  #43
RomeoTango's Avatar
RomeoTango
Following up on this issue to close out. I visually checked the fluid level and it was just above the level indicated in this pic (clutch...basket?). I siphoned 2 ounces out with a Mityvac MV8000 (I had originally added the 38oz called for in the manual), and the fluid is now right at the level indicated. No issues with neutral thus far.
Thanks for all the help!
Old Nov 11, 2016 | 12:53 PM
  #44
FattyMcJ's Avatar
FattyMcJ
Wow, 2 oz. made a difference? I guess I do learn something new every day.
Old Nov 11, 2016 | 02:00 PM
  #45
corliss@bakerdrivetrain.com's Avatar
Glad you got it handled, you could use Crisco and it would work but too much Crisco and....
Old Nov 11, 2016 | 02:16 PM
  #46
perki48's Avatar
perki48
Yep, any oil between the plates will make them stick together/act like torque converter. Thus keeping the gears tight up against each other and causing multiple shifting problems.
Old Nov 11, 2016 | 04:29 PM
  #47
FattyMcJ's Avatar
FattyMcJ
I'm ignorant, so humor me.
Why then are we supposed to soak the plates in oil before install, if any oil between them is bad?
Old Nov 11, 2016 | 06:22 PM
  #48
perki48's Avatar
perki48
Not going to try to explain except that there is a difference between oil ON the plates and the plates sitting in oil. And if you are using the very same plates in a dry system, such as a belt drive, you do not soak them.
15Hogrider
2014-2024 Touring Models
Apr 19, 2017 04:08 PM
escalade6103
Sep 1, 2016 07:00 AM
Stone Cliff
Dec 10, 2014 09:51 PM
escalade6103
Feb 23, 2014 12:24 PM
cgmartine
Dec 17, 2012 05:05 AM
