SENA Communication
Old Jan 1, 2017 | 08:40 PM
rookie06's Avatar
rookie06
Default SENA Communication
Looking for a communication system for my wife. I ride a '14 Limited and she rides a '15 Freewheeler. Is the SENA 20S system compatible with my CB? We ride in a big group regularly and most of us ride limiteds so we have the CB for communication. Wanting something for the wife so she can join in the conversations as well. Don't see anything on their site about being compatible with regular CB's on the various channels.
Old Jan 1, 2017 | 09:21 PM
mike in dallas's Avatar
mike in dallas
I belive you all would have to have Bluetooth headsets to communicate. Might be easier to add the CB
Old Jan 1, 2017 | 09:55 PM
uklauren's Avatar
uklauren
Florida Crew Moderator
No, SENA and CBs don't work together, you can get a SENA each (I think they sell a 2 pack).
Old Jan 1, 2017 | 10:18 PM
TroubleHead Fred's Avatar
TroubleHead Fred
As mentioned the Sena will not communicate with CBs. Your wife will need something like the J&M CB unit to talk with all of you on the CB radios.http://www.jpcycles.com/product/zz38199
Old Jan 2, 2017 | 03:52 AM
_Gir_'s Avatar
_Gir_
Actually SENA can communicate with CBs but you'll need an adapter:
http://www.revzilla.com/motorcycle/s...-radio-adapter
A review from the product describing how they did it:
Perfect for CB integration with other SENA products
II purchased this to use with a CB radio via bluetooth. The concept is good, and overall it works as it should. I have a Midland 75-822 portable CB radio that has an automotive adapter plate. Using a connector cable, I am able to use my CB radio with my SENA 20s headset.
Installation was easy and the kit has all the components needed to mount the unit on the bike. The interface cable for the CB is dependent on the type of CB unit you own so this unit is limited in application based on 5 different CB manufacturers. In my case, I have the interface cable, the switch and a power cable all running to the unit. One issue I have is that connections are located on three different sides of the unit, instead of all located on one side. This makes it a bit hard to mount inside of something on the handlebars, like a windshield bag.
The concept is great. Once the units are paired, there is a switch on my handlebar grip that activates the Tx function of the CB, i speak into the mic of my bluetooth headset to talk. I found sound quality lacking and requiring lots of adjustment to get it right where it needs to be. Plus with all of the configuration options of the SENA 20s, it was difficult to set up everything just like I wanted it, and required a lot of testing. But, I've managed to find what works well for me. Currently, I can be using my 20s in intercom/music mode and any signal received on the CB will interrupt that mode. Likewise if I press the switch it will also interrupt that mode of operation. After a 5-8 second delay the headset returns to the previous mode.
Overall it works well. The unit appears sturdy and is waterproof. You also have the ability to intergrate GPS, radar and external music signals through the SR10, but it's mono-only; no stereo. As with any SENA product, they include just about every mounting adapter you will need which makes it a snap to install and have up and running in no time.
Old Jan 2, 2017 | 05:17 AM
blackxpress's Avatar
blackxpress
The Sena can communicate with CB and other two radios. What you need is a Sena SR10.
Old Jan 2, 2017 | 08:22 AM
StoneyFatBoy's Avatar
StoneyFatBoy
20s won't work with a CB something in the 10 line would though, also if you love the Harley branding HD now sells the SENA 20s for a slightly higher price and with a different name and Harley branding
Old Jan 2, 2017 | 09:35 AM
Mxdad's Avatar
Mxdad
I think the issue if I understand correctly is, his wife does not have a CB on her bike. The SENA can be used with a CB however it has to be connected with a cable to the CB radio on your bike. With his wife having a Sena and no CB she would not be able to hear or join the CB conversations
If the OP and his wife both wear Sena they can of course communicate via the intercom but she would not be able to hear the CB communication without having a CB connected to her Sena
IMHO if he is just looking for something to allow his wife to join the CB communication of the group then she will need a CB on her bike
Old Jan 2, 2017 | 01:06 PM
TroubleHead Fred
Yea, she would still need a cb radio to connect to the Sena, if going that route. The Sena units do not have an 11 meter(CB) receiver or transmitter.
Old Jan 2, 2017 | 07:30 PM
JHL-ShinySideUp's Avatar
JHL-ShinySideUp
Lots of dancing around the short answer:
No, the Sena headsets do not natively connect with CB radios.
You can run a headphone out adapter from the CB to the input jack on the Sena for listen-only in mono.
Or you can buy the Sena adapter, run the CB headset out to the Sena adapter in, and pair the Sena adapter to the headset.
You'll need the button on the handlebar for the push-to-talk CB, and it can take some messing about to get it all working right. And God help you if you ever need to do a factory reset, and set it all up again.
KYBill
Jun 22, 2017 04:17 PM
scarin
2014-2024 Touring Models
14
Jan 16, 2017 02:11 PM
jamesroadking
Jan 27, 2010 11:00 AM
leeinmemphis
Feb 9, 2009 10:49 AM
TxMoores
Aug 25, 2005 11:37 AM
