Bike won't start
Old Jun 13, 2007 | 01:38 AM
clvick3's Avatar
clvick3
Stage III
Default Bike won't start
I own a 1991 Softail, but it has not been cooperating. It has been hesitant to start for the last year and for the past three or four months has not started at all without a push. I do not know a lot about bikes, so I am reluctant to take it to a dealer where they can rip me off. I don't believe it is the battery, because when I turn on the key the lights are quite bright. All I seem to get is a clicking sound when I push the start button. Before these past three to four months I would get the clicking sound, but eventually it would start to crank. Iwould appreciate any help that you all might be able to give. Thanks and God bless!
Old Jun 13, 2007 | 01:41 AM
Greybeardrider's Avatar
Greybeardrider
Default RE: Bike won't start
Get a new battery, it can have enough juice to turn on the lights, but not enough power to crank the engine.
Old Jun 13, 2007 | 01:42 AM
chopperz71's Avatar
chopperz71
Start off with a battery tester. Take it to a Wal-Mart service center, Autozone, ect.. they will test it for you.
Old Jun 13, 2007 | 01:50 AM
timdow's Avatar
timdow
The clicking symptom you have indicates that not enough juice is getting to the starter. There are two main causes:
1) Weak battery
2) corrosion or loose connections
Any auto or motorcycle shop, auto parts shop (Kragen), or even Sears can test the battery (for free!). Have the battery tested. I would best your battery is going South, but if the battery is in good shape, check out the leads for corrosion. check connections of the cables at the engine ground point(s) and at the starter.
Chances are taking these two steps will cure your problem.
Old Jun 13, 2007 | 01:52 AM
gconklin's Avatar
gconklin
it was my battery last year when the same thing was happening to me. listen to these guys...
Old Jun 13, 2007 | 01:57 AM
clvick3's Avatar
clvick3
Stage III
Thanks for the info. I will get right on that.
Old Jun 13, 2007 | 02:33 AM
vertigo14's Avatar
vertigo14
invest in a battery tender and the pig tail you hook it into(stays on ur bike) and keep it juiced up
Old Jun 13, 2007 | 02:50 AM
grezmonkey's Avatar
grezmonkey
6th Gear
check the connector from the volatage reglator where it plugs into the engine block, maybe the battery's not charging? this happened to me last year on my 93 fatboy, like every else said, check the battery first.
Old Jun 18, 2007 | 04:20 AM
timdow's Avatar
timdow
How'd it go?
ClusterFix
Electrical/Lighting/Alarm
Nov 26, 2018 10:33 PM
PierreG
Sep 22, 2015 07:04 PM
Nastyoats
Jul 20, 2011 05:20 PM
gilbertpsk
Aug 23, 2009 09:52 PM
GONZEE
Apr 18, 2009 08:45 AM
