God Almighty does this thing go. Never owned a sport bike before so I'm taking it easy, I don't want to accidentally lift the front wheel when I'm not expecting it. Sounds great, has a fantastic rumble and power everywhere. I still have my Softail, no worries there. Previous owner is a coworker of mine, so I know the history. 10k miles, CR swing arm and sprocket, denoided, Jardine exhaust, custom tuned ECM from HD, heated grips and new tires.
What year is that? Doesn't look like a Sportster motor in there.
2008. The 1125R and 1125CR use 72* DOHC liquid cooled Rotax engines. 146 hp, 10,500 redline. I originally wanted an XB9 or XB12 but this happened to come along.
Awesome! I had test ridden a 1200 Firebolt and Lightening Long. The amount of fun I had on those bikes was ridiculous. I can only imagine the Rotax engine in that chasis. Congrats and enjoy!
I always thought if I went the sport bike route that a Buell would fit my nicely.
I'm not up on the lingo so what is a "CR swing arm" and "denoided"?
The CR is the naked version of the 1125, and it has a different rear sprocket geared more for acceleration. In order to swap the sprocket onto the R model, the swing arm must be changed too. And as far as denoided: The EPA determined that at full whack there was too much intake noise, so there is a little solenoid that partially closes the throttle blades at a given engine speed and load (right before peak torque coincidentally) to prevent this. By removing the solenoid, you don't experience the power drop off.
