HD DOT 4 Brake Fluids
Old Feb 13, 2018 | 09:05 AM
RayHD11's Avatar
RayHD11
Default HD DOT 4 Brake Fluids
Anyone know what is the difference between the HD Platinum DOT 4 brake fluid and the standard HD DOT 4 brake fluid besides one is in a silver label and the other is orange? The Platinum has a little higher boiling point but that's all I can see by reading the labels.
Old Feb 13, 2018 | 09:33 AM
touchdown's Avatar
touchdown
nothing but the price
Old Feb 13, 2018 | 10:50 AM
RayHD11's Avatar
RayHD11
Price is the same...
Old Feb 13, 2018 | 11:05 AM
Cygnusx51's Avatar
Cygnusx51
Probably not much different at all except the packaging to make people think that it will cure the ABS issue. Seems to have settled the NHTSA.
Old Feb 13, 2018 | 11:20 AM
Dynamick's Avatar
Dynamick
In fact it is related to the ABS recall. Harley claims the new Platinum fluid is less likely to gel up after extended use than the old fluid.
Scroll down to Page 9 in the attached pdf to get the lowdown:
https://static.nhtsa.gov/odi/rcl/201...8V076-4574.PDF
Old Feb 13, 2018 | 11:33 AM
Yamaharley's Avatar
Yamaharley
I heard the platinum brake fluid makes the bike fly. It also magically fixes poorly designed abs units.
Old Feb 13, 2018 | 11:43 AM
RayHD11's Avatar
RayHD11
That makes sense, the recall is basically due to lack of maintenance by owners not following maintenance time schedules... The new formula has less deposits over time which can lead to brake failure.
"The new DOT 4 brake fluid that will be used for the remedy flush [H-D
Platinum Label DOT 4 Brake Fluid] has a different chemical formulation
which has been shown in our testing to be less susceptible to the
formation of gel and, ultimately, deposit formation inside the braking
system. Owners will also be reminded of the 2-year maintenance cycle
specified in the Owner’s Manual."
Old Feb 13, 2018 | 02:53 PM
Cygnusx51's Avatar
Cygnusx51
I’ve read that and that’s why I made that comment. Who did that testing? NHTSA or was it information that was submitted by HD? Like I said, I doubt there’s any difference and it’s just to get people a fluid change and a reminder of the 2 year interval. After this, it leaves HD in the clear should an issue arise because they can just fall back on the excuse that people aren’t following the recommended service intervals.
KumaRide
Jan 24, 2020 07:16 AM
Dcampri
Jul 7, 2017 08:17 AM
rhd01
Feb 6, 2016 07:09 PM
maryvillept
Jan 24, 2015 11:45 AM
rebelpiper
Jun 4, 2013 04:16 PM
