CVO cuts off
Old Jun 23, 2018 | 01:37 PM
Nathaniel Barnhill Jr's Avatar
Stage III
Angry CVO cuts off
Has anyone had the bike to cut off and low power, run for a short period then cuts off again.
I have about 25000 mile on the bike.
Old Jun 23, 2018 | 02:05 PM
Cygnusx51's Avatar
Cygnusx51
Check to see if the plug wires are rubbing the bottom of the tank.
Without knowing what year/model bike you have, what mods have been done, or any other info other than it being a CVO, there really isn’t much in the way of help that people can give you.
Old Jun 23, 2018 | 07:50 PM
Flstcjay's Avatar
Flstcjay
More info. Bike hot? Burning smell? Hard start? Run rough? Die at idle? Misfire at RPM?
Old Jun 23, 2018 | 08:28 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Yeah, plug wires as mentioned above. Also the wiring plug in connector under the tank behind the throttle body. They give problems. Pull it apart, clean very well, lube with dielectric grease and reconnect.
Check engine light on?
Any codes?
Old Jun 23, 2018 | 09:45 PM
2AMGuy's Avatar
2AMGuy
First thing(s) that I'd check is the VOLT meter. Is it reading above "12" at idle and does the needle move upward towards "14" when you rev up the engine?
Next, are you sure that your battery is fully charged and does the VOLT read at least "10" when you turn on the ignition before starting?
Old Jun 24, 2018 | 06:17 AM
scumBAGGER's Avatar
scumBAGGER
throttle by wire
Old Jun 25, 2018 | 10:52 AM
Stage III
All of that is good
It is a 2009 CVO no mods have been done stock FLHTCUSE4
None of this happening with the bike.
Old Jun 25, 2018 | 11:14 AM
Screamin beagle's Avatar
Screamin beagle
The sensor in the throttle grip or like someone else said the plug on the throttle body is a known issue, peel back the covering and look for a bare wire, wiggle each wire with the bike running to see if one broken inside the insulation, look for a broken pin inside the plug and then clean and grease it up. Sorry for the lack of punctuation lol.
Old Jun 25, 2018 | 02:38 PM
Stage III
Default CVO cutting off
Thank you for the help that was the problem broken wire in the plug.
Old Jun 25, 2018 | 10:21 PM
2AMGuy's Avatar
2AMGuy
FWIW, I had a '00 Ultra that would sometimes quit running, and a other times would be difficult to restart until after it had sat for a few minutes.
This turned out to be a faulty "kill" handlebar switch.
Never had a "low power issue" but this sounds like a fault somewhere in your ignition system.
You need to check for "coding" and see if that offers any assistance.
mikes300
Audio Systems
Feb 22, 2019 09:28 AM
bigfish_Oh
2014-2024 Touring Models
Aug 8, 2016 11:26 PM
hapbob
13
Feb 16, 2015 04:50 PM
bks
Jun 9, 2013 05:22 PM
Hashash
Apr 30, 2012 05:18 PM
