Rocker Lockers
Old Jul 30, 2018 | 07:49 AM
Jonny Rotten's Avatar
Jonny Rotten
Default Rocker Lockers
I just got a pre owned 2015 Road King with a 103. It has 22K on it.
My first instinct was I got a beat motor. The ticking drives me insane. Every time I take it out at some point in the ride I think to myself "this guy must have killed this motor" But the general consensus is its normal due to HD cutting corners and using a smaller bolt than they should have to lock in the rocker shaft. My riding buddies cant hear the ticking and think I'm crazy but it's there. I feel like I'm damaging the motor just by running it.
Anyone have ant input on installing Rocker Lockers?
I've never pulled an engine apart but it seems pretty straight forward.
Old Jul 30, 2018 | 08:06 AM
tjcaron's Avatar
tjcaron
There’s some pretty long threads on here about them and the install. John from Rockout is a member here and I’m sure can help out if needed. Biggest thing that I can say is to get a service manual if you don’t have one.
Old Jul 30, 2018 | 08:07 AM
Veekness's Avatar
Veekness
As I replied in yer other thread, my go to for top end noise is Rockouts. I have no experience with Rocker Lockers, but I've found that Rockouts are inexpensive, easy to install, and in all five cases that I've installed them, have solved the problem. Additionally, the proprietor of Rockouts is active on this forum, and not just for issues involving his products.
That's not to say that they will work in all cases. All Harley engines are just a little different from.others, and sometimes, try as you might, ya just can't get a noise out of an engine.
But I'd give the Rockouts a try for certain.
Old Jul 30, 2018 | 08:26 AM
Jonny Rotten
If I knew the guy from Rockout was a member I would have referenced them instead. I did a search and they both came up so I picked one. I'll pick up a service manual.
Old Jul 30, 2018 | 08:31 AM
Uncle Larry's Avatar
Uncle Larry
A service is a wise investment, however they won't reference the problem ...
https://www.google.com/search?q=rockout+harley+rocker+shaft+inserts&sourc e=lnms&tbm=vid&sa=X&ved=0ahUKEwiHwN6o98bcAhWk4IMKH bHoDH4Q_AUIDCgD&biw=1493&bih=741
or
https://www.google.com/search?biw=14....0.gbX_tk4EA4I
Old Jul 30, 2018 | 08:35 AM
n5tf's Avatar
n5tf
Did you change the oil or running what it had when you bought it?
Old Jul 30, 2018 | 08:38 AM
Veekness's Avatar
Veekness
The FSM is an excellent investment, OP...although it doesn't reference your particular problem, it does tell you how to access the rocker assembly and reassemble it all.
leachman
May 13, 2018 06:50 AM
Michael Costello
Jul 23, 2017 07:29 AM
HDV-GLIDE
Jan 25, 2016 02:48 PM
Varooom
Oct 21, 2011 03:58 PM
hotrod351
EVO
May 27, 2009 09:12 AM
