Revving the Engine at Start Up
Old Sep 5, 2018 | 08:01 PM
  #41
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
Didn't read all the responses, but a short "blip" or even two is a good way to get oil to the motor quickly. I say not more than 2K RPMs and a very short time, then let it warm up a minute or so, and even then, don't blast the throttle, for another 5 minutes or so.
To answer your question, It sounds like hes not hurting it, but kinda needs to repent!!
Old Sep 5, 2018 | 08:13 PM
  #42
tar_snake's Avatar
tar_snake
Originally Posted by RET_SCPO
I still blip the throttle when I down shift and there's probably no reason to do that although it does seem to make for a smoother down shift IMO. It's a habit that started back when I started riding....
Blipping while downshifting to make the shift smoother is *exactly* the right and good thing to do. It makes things supremely easier on the trannie and the drive chain and belt, not to mention easier on the rider and passenger if there is one.
Old Sep 5, 2018 | 08:15 PM
  #43
tar_snake's Avatar
tar_snake
Originally Posted by uklauren
It's not a complaint, my solution is to park away from him
I'm a woman
I hit the target at the range, pretty good actually
I'm just asking if it's bad for the engine, if you don't know then why bother whining on here?
You, started the whining.
Old Sep 6, 2018 | 03:36 AM
  #44
Kingglide549's Avatar
Kingglide549
Woman card.!
They get away with starting crap and then blaming someone else.
Old Sep 6, 2018 | 06:07 AM
  #45
Campy Roadie's Avatar
Campy Roadie
Originally Posted by Sierra Nate
The argument about cold engine needs lube makes no sense. The oil pump is driven by the crank, right? The faster it turns the quicker the oil gets to the top and sumps out of the bottom. Reving an engine when cold without lubrication would cause clatter in the lifters, no? I never hear clatter in my lifters on startup (or ever for that matter).
Is it unnecessary? Is it annoying? Those are different questions. She asked if it would be bad for the engine. I see no evidence it is bad for the engine.
Even though the TC and M8 oil pump is driven by the pinion shaft of the crank it still takes time to spool up the pressure. To be sure, the real damage on a cold engine comes from the fact that Harleys are all air cooled engines (despite what BS HD sold you). That means parts like pistons, rings, cylinders, heads etc all have built in tolerances to "grow" to operating size. When all those parts are cold they are effectively smaller and increase in size at different rates according to material they're made from, ie aluminum (forged or cast) iron, or steel. Revving a cold engine (not a throttle blip) before the operating temps are up and the parts have not yet expanded will push blow by past the rings. In the case of a fuel enriched carb or fuel injected bike, the additional fuel will also be pushed past the rings and into the crankcase.
This would be a good thread to refer back to when anyone here puts a bike for sale in the classifieds. A person's honest answer one way or the other is more important than "never seen rain". A polished, beat up, low mile turd is worth less than a bike with paint nicks, worn out tires and more miles if it was cared for my someone who knew something about motorcycles.
Old Sep 6, 2018 | 06:39 AM
  #46
Chris gibson's Avatar
Chris gibson
I watched an s&s video about using chevy lifters in harleys(don’t do it) but it showed it lakes at least 1minute to get oil to your top end even with s&s premium lifters. I usually let mine idle for a minute or so b4 I even hit the road. It’s a s&s video online. Chris
Old Sep 6, 2018 | 08:38 AM
  #47
DROD13's Avatar
DROD13
haha my father revs his engine slightly every time he starts his bike. It drives me nuts but I know he's just enjoying his bike so I keep my mouth shut.
Old Sep 6, 2018 | 08:48 AM
  #48
Kingglide549
Does he own an old Shovel?
Or perhaps he did ........
Old Sep 6, 2018 | 09:07 AM
  #49
Sarah93003's Avatar
Sarah93003
Originally Posted by Kingglide549
Woman card.!
Go back and read the first post. There was no whining there and no drama. The only drama in this thread is some of the responses. You two need to change your manpons.
She asked a simple question, is it bad for a cold motor to be revved? That's all she asked and received some thoughtful responses. The first couple of sentences just established how much he is revving.
Lauren, my guess is it's a habit from days gone by. I've ridden with a lot of people over the years and lots of guys blip the throttle. I remember back in the 60's and 70's when I first started on dirt bikes we always blipped the throttle after starting. I think it was so it wouldn't stall. With all of the electronics these days I don't think that is necessary. Someone mentioned placing your hands over your ears as a gesture of how loud it is. That's a pretty good idea, I think.
Old Sep 6, 2018 | 09:24 AM
  #50
Kingglide549
Is not complaining about someone else whining?
It would seem to me the more direct approach without the passive aggressive crap would be the best course of action.
The clown act hands over ears or other antics is just so modern nowadays along with cry closets and safe circles.
