So I Rode out to Milwaukee for the 115th with a co worker. He has a 2017 semi liquid cooled107, i have 2012 air cooled 110. As the trip went along i noticed I was using more fuel that the 107. As of his 1/4 tank i was almost empty. Both are stock bikes. Why is there so much of a difference? just the differences in the engine? thanks Jeff
He haas a 2017 limited nearly the same except for the buffeting feature in the fairing
Reason: Multiple posts
Wind resistance has a lot to do with it, and it looks like you're pushing an awful lot of wind. What is the profile of his motorcycle?
What's a "buffeting feature", and which motorcycle has it, yours, or his?
After wind resistance, tire pressures and laden weight would be the next two things to look at.
Effective final-drive gearing can have an effect also.
But I am skeptical that two late-model fuel-injected motorcycles that similar would be significantly affected by the differences of the two engines- they should be running pretty close to stoichiometric at a steady-state cruise on the highway. His liquid-cooled engine may have a higher compression ratio (which would help his fuel mileage), but I still would look at wind resistance first, then tire pressures and laden weight.
What kind of fuel mileage are each of you getting?
I typically get around 40 mpg or so on the highway when sitting up, and on longer trips if I rest my elbows on the tank and cross my forearms (to work the throttle with my left hand), I get around 50 mpg. Wind resistance is HUGE.
I have a '13 CVO Ultra with the 110 which as been dyno'ed and has a H-D tuner and Rinehart XT True Dual Exhaust.
Cruising at basically 70MPH, or on two lane roads where my RPM's remain under 3,000 RPM's (or so) I get approximately 40 MPG's
My riding part had a '10 Ultra that was updated from a "96" to a "103", also dyno'ed with the H-D tuner, a fuel-moto dual exhaust pipe and Rinehart mufflers and when we ride together our fuel consumption is nearly identical (usually within 1/10th of a gallon at fill-up).
Higher speed, faster take-off's wind, terrain, even fuel (especially non-ethanol gas if available) can make your fuel consumption fluctuate.
My bike seemed to get better mileage with the OEM exhaust but I thought getting ride of the catalytic converter and having a Harley that sounds like a Harley was well worth a mile or two per gallon.
I did notice that when we both fueled up that when you look at the run to empty setting on the odometer i would be around 194 he would be about 240 most always a 40 mile difference which would be about 1 gallon.
Honestly with the reliability of the gauges and range to empty you really need to compare hand calculated mileage or at least take mental notes of how much fuel each bike is taking per fill up.
FXDXTSport's thread looks like it might be pretty helpful. It could just come down to small variances in riding style (accel rates, shift points), tunes, mods, etc.
