I adjusted it but...
Old Jul 7, 2007 | 07:07 AM
vulhalla's Avatar
vulhalla
Default I adjusted it but...
ok, took the derby cover off, loosened the cable adjuster, loosened the locknut, turned the adjusting screw in and pulled the clutch handle in 3 times, turned the screw in again till it botomed out, backed it off 1/2 turn, tighented locknut, tightened cable adjuster, pulled clutch handle in a few times and adjusted lever so its 1/8 play in cable and put derby cover on.
gears 1,2 4 and 5 are so quiet you cant hardly hear them, 3rd still has the clunk...
made sure all fluids are full....
did I do this right? according to the DIY, the manual and the fix my hog video i did....
Old Jul 7, 2007 | 07:10 AM
tbone52's Avatar
tbone52
Default RE: I adjusted it but...
Sounds correct to me. That's exactly what I did. Mine has been fine for almost 5,000 miles. Time to do it again.
Old Jul 7, 2007 | 07:27 AM
vulhalla's Avatar
vulhalla
I just found in the DIY that if its hard to shift it could be a primary chain adjustment, is that correct?
maybe ill tightenen it a bit
Old Jul 7, 2007 | 09:16 AM
1flhtk4me's Avatar
1flhtk4me
You could try to tighten the cable up a little.1/16 min.
Also check primary chain.
Some people claim that changing the tranny fluid to Redline Heavy Shockproof works.
Old Jul 7, 2007 | 03:10 PM
Tnicean's Avatar
Tnicean
I do my own service, too and I was adjusting the clutch every 5000 miles per the service manual. I decided not to do that any more and I will adjust it when it needs it. I think it is the 5000 mile service interval to adjust because a lot of people would not even know when it needs adjusting, but I DON'T think the service tech necessarily does the full adjustment if it feels right to them. Just my opinion. I'll adjust the clutch when it begins to feel like it needs it.
Tnicean
Old Jul 7, 2007 | 08:47 PM
vulhalla's Avatar
vulhalla
so do you guys shifter still clunk?
Old Jul 7, 2007 | 09:06 PM
Gadgetech's Avatar
Gadgetech
ORIGINAL: 1FLTRI4ME
I have the shockproof heavy and have noticed no difference in clunkiness.
Old Jul 8, 2007 | 10:25 AM
1flhtk4me's Avatar
1flhtk4me
ORIGINAL: Dynamite
I agree.I'm using the same.This is why I wrote "some people".
Old Jul 8, 2007 | 08:01 PM
Tnicean's Avatar
Tnicean
It's supposed to clunk.
Tnicean
JockWhisky
Feb 11, 2011 09:01 PM
devilock76
EVO
Sep 13, 2009 09:36 AM
Razorback Rob
Jul 23, 2009 09:53 PM
Ace2000
Jun 20, 2009 08:06 PM
Whiffleboy
Oct 27, 2008 08:08 AM
