Hey guys i pulled the Diag Code from my bike and i got these
ECM
P0572 Brake switch low
PN001456-01
ABS
C1094 Front brake switch always on
C0562 System Voltage Low
PN 40800041
How much will this cost me to fix including parts and labor?
EDIT: just bought a new battery recently but after the 2nd day battery has a hard time cranking right away i think the stage 5 is causing the low voltage problems but the battery is under warranty.
If you know of a Good DTC App for Android please provide links thank you <3
