Refinishing the forks... Rattle can job?
Old Nov 9, 2019 | 04:38 PM
TroubleHead Fred's Avatar
TroubleHead Fred
^^ I don't remember what brand clear coat I used but I bought some of the better stuff from the parts store. I would just avoid the $0.97 stuff from Walmart and you should be fine. I've used Krylon on things in the past and had it turn out decent, use several coats.
Old Nov 9, 2019 | 05:36 PM
GREENOHAWK69's Avatar
GREENOHAWK69
https://www.spraymax.com/en/products...2k-clear-coat/
Used this on the wheels of my Ducati M900 that were rattle canned and holding up well.
Old Nov 9, 2019 | 05:54 PM
MyFavRk's Avatar
MyFavRk
Excellent , thanks guys ! Appreciate the help . I'm guessing just a good quality clear will do the the job . It's going to be awhile before I actually get to it , only have about 20,000 km on these tires now . If I get ambitious enough I may just do it this winter . Again Thanks !
Old Nov 9, 2019 | 06:06 PM
uncle kebo's Avatar
uncle kebo
I had an 04 that I fine sanded the scale off, then polished with Flitz then used sharkhyde to coat them.. Looked great for a long time too
Old Nov 9, 2019 | 06:22 PM
rizzo's Avatar
rizzo
If you want it to hold up well use Spray Max 2K two part clear. It's expensive for rattle can at $18-20 a can but applies well and is as durable as your other painted parts. There are a few threads on here where members have used it and had great results.
There are pics in this thread of a couple projects I did using Spray Max. When you look at the pic of the rear fender you'll see the reflection of the tree that was behind me when I snapped the pic.
https://www.hdforums.com/forum/evo-c...-fairings.html
Old Nov 9, 2019 | 06:27 PM
MyFavRk's Avatar
MyFavRk
I do recall reading a couple of those posts back in the past . I'm pretty sure one of the dealers I use for auto parts carries that stuff . I'd rather buy a good quality clear and only have to do it once . Much appreciated Rizz
Old Nov 9, 2019 | 09:07 PM
P51Driver's Avatar
P51Driver
The spray max two part clear is good stuff. But remember you will still have to wet sand the clear to get rid of the orange peel that you will have.
Old Nov 9, 2019 | 09:27 PM
MyFavRk's Avatar
MyFavRk
Will do , I've painted with rattle cans in the past , did my hardbags , sidecovers , fillers etc . I just wasn't sure about clear coating over bare aluminum . Wet sanding definitely makes the finish project look more professional . Appreciate the heads up ..
Old Nov 10, 2019 | 09:44 AM
RHPAW's Avatar
RHPAW
I pulled everything off the bike and chromed it.
The bugs around here have a Superglue quality to them that would pock-mark anything else.
Cap77
Feb 14, 2020 03:08 AM
Devils Cut
Sep 10, 2012 02:28 PM
crazy_walt
Jun 24, 2011 12:09 AM
JakesDad1
Jun 6, 2011 10:50 PM
rwskinner
Detailing
Oct 30, 2007 09:00 PM
